Best way to have in-model supports
[Risolto] Best way to have in-model supports
FuziPrint
(@fuziprint)
I have a model that has a slot where another part gets inserted later. It is like a bridge that needs to be supported. I used smart fill in paint-on supports. The one thing is that it puts a layer on the build plate that serves no function that I can see. Is there a way to get rid of that layer?
Is there a better way of doing this type of support than what I did?
Also, what are the best settings for making the support removal as easy as possible while keeping the dimensions of the slot accurate? i.e Top/Bottom contact Z distance, etc.
Attached the model and settings bundle.
Postato : 28/06/2022 5:14 pm
Tim Weston
(@tim-weston)
To get rid of that first layer support that does nothing, set the 'First layer expansion' field in the 'Support material' tab to '0'.
I can't comment on the optimal settings for support removal but others may have some input for you.
Cheers,
Tim
Postato : 28/06/2022 6:59 pm
RE: Best way to have in-model supports
Your support settings should be fine the way they are. Just do what Tim said and set first layer expansion to 0.
Postato : 28/06/2022 7:18 pm
FuziPrint
(@fuziprint)
Thanks, that worked.
Postato : 28/06/2022 8:58 pm
BTW, if you upload a 3mf file there's no need to include a configuration bundle as it's all included in the 3mf.
Postato : 28/06/2022 9:09 pm
FuziPrint
(@fuziprint)
Cool, thanks. I was not sure...
Postato : 28/06/2022 9:20 pm
gjwep gjwep
(@gjwep-gjwep)
Utenti
Can this also be done for SLA prints?
Thanks!
Postato : 04/01/2024 10:40 am
