'Bad Allocation Error' When slicing
mighizer
(@mighizer)
Updated to the new slicer and when I slice more complex or full plates of models I usually get a bad allocation error. Also says I may be reaching the limits of my RAM.
Haven't run into this issue before but I did end up putting another 8GB of RAM in to see if that would help.
Now I just get to the Error faster haha.
Anyone have an idea what this may be and how I can fix it?
Thanks in advance!
Opublikowany : 02/10/2019 4:37 am
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
RE: 'Bad Allocation Error' When slicing
Aren't you running a 32bit slicer on a 64bit machine?
Maybe you are generating a gyroid infill on a huge model?
It helps us the most if you open a ticket at https://github.com/prusa3d/slic3r/issues and provide as much as possible information to the issue, including your PrusaSlicer project file. Thank you.
Opublikowany : 02/10/2019 8:03 am
mighizer
(@mighizer)
@bubnikv
Thanks - Yea I noticed last night that I'm running 32 bit slicer on a 64bit machine...cant find any other options when downloading the new slicer. There is just one button for the file. Am I blind?
Opublikowany : 02/10/2019 12:23 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
I have to check with the guy who made the Windows installer. Did you install the drivers package, or did you install the zip file from github?
Opublikowany : 02/10/2019 12:40 pm
mighizer
(@mighizer)
Running the 32bit on the 64bit machine was the problem. Found the correct version file on github. There you can select 32/64bit.
Doesn't look like you can choose if downloading from prusas site.
Opublikowany : 02/10/2019 1:19 pm
Sembazuru
(@sembazuru)
Posted by: @aaron-d18
Odd. I installed from the drivers package from the Prusa site on my Win10 (Windows 10 Pro v1903) laptop and the installer correctly chose the win64 version:
Maybe there is something unique about your system that is confusing the installer. What version of Windows do you use?
I won't have access to the only Windows pre-10 (I forget if it is Win7 or Win8) that I've installed Plicer on until Monday to see which version was installed there, but I don't recall any errors being thrown when using it.
See my (limited) designs on:
Opublikowany : 02/10/2019 1:26 pm
I run Win 7 x64 and the installer placed this on my machine:
Opublikowany : 02/10/2019 9:33 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
Thanks for heads up.
Opublikowany : 03/10/2019 6:35 am
