avoiding rapid traverse
J.P. Ryll
(@j-p-ryll)
Hey there,
could one of you tell me how i cloud avoid rapid traverse, over void, in Prusa-slicer? (like the blue lines in the picture)
I try to print TPU an these thin Threads are horrible.
in Cura there is an option called "combing"
Thank you Mates!
Greetings from Germany!J.P.
Opublikowany : 22/06/2020 3:48 pm
Area51
(@area51)
RE: avoiding rapid traverse
You can try the setting "Avoid crossing perimeters", but I think this function "is kind of broken" as travel moves will still be across perimeters and the movement is not optimized. I have seen several forum post about that problem.
Opublikowany : 22/06/2020 9:41 pm
jsw
 jsw
(@jsw)
There's an option in Prusaslicer to adjust the speed of non-print moves as well.
Opublikowany : 23/06/2020 4:30 pm
fdelam
(@fdelam)
With a combination of "avoid crossing perimeters" and extrusion width adjustement, i think you will be able to print this with no traverse move or at least a lot less.
Opublikowany : 27/06/2020 3:34 pm
