Automatically adding a topping
Lam
 Lam
(@lam-2)
I am willing to print a paint holder look like this:
but Prusa slicer slice it like this:
where it automatically fill up top cover. How can I remove them?
Opublikowany : 26/12/2021 8:03 am
RE: Automatically adding a topping
That is usually (almost always) down to a broken model. Fix the model and it will slice properly.
If you are on windows then there should be an option in Prusa slicer called fix through netfabb , that can often fix a broken model automatically.
You would have to post either a saved project file from PS (preferred) or the model file to be certain. Remember you have to zip up files to attach them to the forum.
Opublikowany : 26/12/2021 8:22 am
Where did you get the part file?
If it is your own work you probably have a computed difference issue.  If the cut-out height within a shape differs in the unpteenth decimal place from that of outer case then it's possible to leave a micro-thin layer in the output file.
The answer is to add a little to the height of any cut-out to make sure the inner difference fully penetrates the outer.
Opublikowany : 26/12/2021 8:32 am
