        Automatic Temperature Adjustments per Printer
I have four Creality CR-6 SE printers, and I have upgraded half of them to MicroSwiss All-Metal Hot Ends. For those two printers, I must print pretty much every filament 10° hotter than I do on the ones still with the stock hot end. I made a new profile for those with the new hot end to account for retraction differences. Is there a way to tell PS to have my printer add 10° to the standard printing temperature, or do I need to create separate filament profiles (or manually change the temperature in the filament profile) for now? Would changing my start GCode line:
M104 S{first_layer_temperature[0]} ; set final nozzle temp
to:
M104 S{first_layer_temperature[0]}+10 ; set final nozzle temp
resolve my issue, or will it go back to the original temperature once it hits the second layer?
                            Veröffentlicht : 09/06/2022 2:25 pm
