Automatic color change not showing up anymore
shags72
(@shags72)
I have an stl that I sliced and the looks like a logo popped up and worked great. Then I needed to scale the model and it didn't come up after deleting the color change and I have not been able to get it to come back up on this model. Any ideas why?
Opublikowany : 01/02/2024 12:46 am
Because you scaled it outside of the automatic detection range.
Drag the slider at the right to the place where you want your colour change(s), click the + sign on the slider and reslice.
Opublikowany : 01/02/2024 1:29 am
shags72
(@shags72)
RE: Automatic color change not showing up anymore
Ok, but I usually just remove the color change from the slider and reslice and the dialogue comes up asking if I want it to select the color change for me. I can select the color change location but it's easier and quicker to have the system do it and it won't.
Ok I reread and you say out of the detection range. What is that range? This scale was to increase the width of a certain feature, I don't really need the extra Z distance. I could cut it.
Opublikowany : 02/02/2024 8:29 pm
I don't know the figure, If a step is too big or too small it will not be detected automatically - but you can always add it manually.
https://help.prusa3d.com/article/color-change_1687#automatic-color-change
Opublikowany : 02/02/2024 11:47 pm
1 ludzie polubili
