Auto Arrange, gap between objects
men8ifr
(@men8ifr)
I have 40 objects that easily fit on the build plate but auto arrange cannot do it? They are simple circular shapes and it's a pain to arrange them manually each time.
I think the problem may be the gap left between objects, can I reduce this?
Veröffentlicht : 16/09/2020 8:17 am
Mitglied
RE: Auto Arrange, gap between objects
Not that I am tracking.  Here is more on this feature:
https://help.prusa3d.com/en/article/auto-arrange-tool_1770
Veröffentlicht : 26/09/2020 7:56 pm
I assume you mean spaced for sequential printing?
PrusaSlicer can certainly arrange large numbers of parts on the bed. IME, it arranges everything in a tight pattern. Here's a full bed of 643 pegs. It takes a while after hitting the auto-arrange button (highlighted) but it works.
If I reduce the peg count, they cluster around the center.
Veröffentlicht : 27/09/2020 2:52 am
Velode
(@velode)
Right click on the arrange button (Slic3r 2.5.0) and you can set space manually. You can even rotate, like a poor mans nesting...
If you hover over the buttons (most of them in slic3r) you'll see options available....
Veröffentlicht : 27/11/2022 5:21 am
