Artifacts in layer when print multi color. Slicer Bug?
FatCats
(@fatcats)
I am making a multi color box and with lid using 5 different colors.  The pattern is 2 45's from each side of the box, several about 10mm thick, in a "V" shape.  I got it all colored, sliced it and noticed that it wasn't flat on the build plate.  I flattened it and re-sliced it.  Now I am getting 1 thick (high) layer lines from extruder 1 all over the place on the face of the box.  I back it up so its not flat on the build plate again and slice it.  Artifacts are gone.  Flat it again and they are back.  Slicer bug?
First picture is before laying flat.  Second is after lay flat and 3rd is what the artifact looks like.
Is there a fix, or am I doing something wrong?
Thank you in advance.
Napsal : 21/12/2025 12:27 am
RE: Artifacts in layer when print multi color. Slicer Bug?
People are going to need your prusa slicer project to examine to give any sort of meaningful response.  File>Save project as and then take the 3mf file produced, ZIP it up and attach the zip file to a reply here.
Napsal : 21/12/2025 11:35 am
FatCats
(@fatcats)
zip file of the 3mf attached below.
color box
Napsal : 21/12/2025 9:52 pm
Robin
(@robin)
As a matter of fact there are some of these artifacts even before putting the box flat on the printbed, is this the first version of the project after painting or did you already move the box?
Looks like a bug in the multimaterial painting caused by the very small angular changes when repositioning the box flat on the surface.
Napsal : 22/12/2025 12:46 pm
FatCats
(@fatcats)
It was the first version.  Re-sized, tilted on a 45deg, lined then tilted 255deg and lined.  Placed back at 0 and flattened to bed and the lines showed up only after flatting to the bed.
The print lines, when solid color don't show the artifacts.  For some reason Prusa Slicer is creating this odd g-code.  I attached the STL for the box, if you want to try it.
Box with lid
Napsal : 22/12/2025 1:46 pm
