Archimedean Chords line skipped
bce.gatien
(@bce-gatien)
Utenti
Good day,
This is my first post and English is not my first language. 🙂
I use Archimedean Chords for top and bottom fill pattern. I do realize that on most print, the Top and bottom pattern is inconsistent. Looking at the G-Code, I realize that the lines are not always printer in order. Every time a line is skipped and printer out of order, the finish is uneven. You can see it and feel it. I did my best to put side by side a picture of a test print and the G-Code as showed in PrusaSlicer in the following picture :
I use the basic setting on the MK4, 0.4 0.20mm PLA
Is there a way to ask PrusaSlicer to print the top and bottom layer Archimedean Chords in order ?
As a note, a similar situation happen with Octagram Spiral
Postato : 09/01/2024 5:46 am
zjohnson16
(@zjohnson16)
Utenti
RE: Archimedean Chords line skipped
I also have this same issue, I don't think the capability exists in the slicer yet. In the meantime you might improve the finish by slowing down the print speeds on the top layer. It also looks like you might have slight underextrusion.
Postato : 13/01/2025 6:05 am
