api-ms-win-crt-runtime-l1-1-0.dll
Heine Sørensen
(@heine-sorensen)
Hi , Im completely new here (not to 3D printing) , I run a old gaming PC (very powerfull but old ) with Windows 7 and I cannot get the prusa slicer to work. ..this error comes up......"api-ms-win-crt-runtime-l1-1-0.dll" is missing.
Since the windows 7 is not updated Anymore I do have a real problem because I love my old PC and WIN7 🙂
I have tryed many things/solutions found online but nothing helps. also the older versions of slicer gives the same error
I do have a original MK3S+ in the pipeline and also a MK3S Bear clone, so some help will be great thanks 😉
Regards
Heine Sørensen
Denmark
Postato : 02/02/2021 6:48 pm
Saibot
(@saibot)
RE: api-ms-win-crt-runtime-l1-1-0.dll
Hello
Have you solved the problem?? I have the same issue under windows 8
first i have downloaded all the missing dll files. after that there was an new error.
in conclusion it just doesnt run and i tried for many many hours.
Postato : 16/04/2021 8:32 am
Heine Sørensen
(@heine-sorensen)
@saibot
No , currently running with another PC (laptop) with Win 8.1 and that one is working , however I have not given up just yet , I have a friend that will look on the issue (Fellow printer and IT software specialist by trade) so maybe he can solve the issue soon.
Postato : 16/04/2021 8:44 am
Heine Sørensen
(@heine-sorensen)
@saibot
Note, the old laptop was reset and started up with Win8 and the slicer is not working on that version , some time later it asked to be updated to 8.1 and then I tried again and the slicer works fine now
Postato : 16/04/2021 8:47 am
3Delight
(@3delight)
Moderatore Moderator
Try reading this: https://answers.microsoft.com/en-us/windows/forum/windows8_1-pictures-musicapp/api-ms-win-crt-runtime-l1-1-0dll-is-missing/b593b94e-6691-423b-a586-0b7f10131e35
Basically, the missing file is part of "Visual C++ Redistributable for Visual Studio 2015" so you need to find and install that.
I was reluctant to move on from Windows 8 due to all the moaning online but I love Windows 10 now and have had no problems at all.
Postato : 16/04/2021 8:52 am
1 persone hanno apprezzato
Tim A
(@tim-a)
Windows 7 Clean Parallel Install over Windows 10
I recently installed Win7Pro on a new partition over Win10. PrusaSlicer 2.3.3 works fine in the Win10 environment, but not in the new Win7Pro environment. I get this error when trying to run it:
The procedure entry point ucrtbase.terminate could not be located in the dynamic link library api-ms-win-crt-runtime-|1-1-0.dll.
I am trying to keep the Win7Pro installation as clean as possible, but I am obviously missing a correct .dll file somewhere.
I installed Win7Pro because my old SolidWorks 2001 won't run on Win10. It runs fine on Win7Pro. It is a hassle restarting every time I want to slice a solid for printing.
By the way, I am totally new to 3D printing, and just ordered my Prusa Original Prusa i3 MK3S+ kit and am excited to get started.
Help is greatly appreciated. Thank you.
Tim
Postato : 18/09/2021 8:06 pm
Tim A
(@tim-a)
Solved!
I found a copy of Microsoft Visual C++ 2015 Redistributable and installed it. Works flawlessly now!
By the way, the MK3S+ kit is  a marvel. The assembly process went well due to the well-written instruction manual. The most difficult part was finding a flat surface! Tables, countertops, work benches  - all had some sort of flaw. I found that the 24" tiles on the floor of our guest bath were the flattest surface I could find. The only thing better would be an industrial granite surface table.
Tim
Postato : 04/10/2021 5:33 pm
