Any way to control detraction?
Tobycwood
(@tobycwood)
I've been trying to figure out why I am seeing large extrusion blobs on Paint on color prints. This is with a tool changer.
Initially I thought these were from incorrect retraction at the seams. But looking at the gcode I now see that the over extrusions are actually happening when a tool has just been picked up and just starts to print. Right where the problems happen I see the G11 command. My extrusion length (which I've set in FW) is optimal yet there seems to be no way to control the detraction. Any ideas?
Publié : 23/06/2022 8:46 pm
Swiss_Cheese
(@swiss_cheese)
@tobycwood
The controls for detraction are in two places, (1) Printer Settings/Extruder [Retraction] its listed as detraction speed (normally set to Zero) at which point it takes on the speed attribute of the Retraction speed, and (2) in Filament Settings/Filament Overrides, and changing the speed has an effect.
Hope this helps.
Swiss_Cheese
Ce message a été modifié il y a 4 years par Swiss_Cheese
The Filament Whisperer
Publié : 23/06/2022 9:21 pm
Swiss_Cheese
(@swiss_cheese)
RE: Any way to control detraction?
I received an e mail saying you responded. however I'm not seeing your full response, and don't know what your trying to say, I blame the Prusa server for this, however if you deleted the response, I may also not see it.
Sorry, I wish I could help farther but this happens fairly often here, and has been happening even more so in the past few weeks, almost like a few months  ago when the website really sucked.
So, good luck, maybe you'll find what you need, use google to search because the website search is Awful.
Swiss_Cheese
Publié : 24/06/2022 12:40 am
Tobycwood
(@tobycwood)
I solved the problem. It’s actually related to the setting Retraction when tool disabled for each extruder. I had the same thing happen with Simplify3d… the detraction occurs after the prime/wipe. The fix is to put into the setting Extra length on restart a negative number which negates the detraction after the priming.
yeah it’s a hack but it worked.
Publié : 24/06/2022 2:33 pm
Swiss_Cheese
(@swiss_cheese)
Well it is a tool changer, not specifically a printer, so you have to do what you have to do, hack away.
Swiss_Cheese
Publié : 24/06/2022 3:05 pm
