After adding pause can't slice again
Oliver Züllig
(@oliver-zullig)
Utenti
Hey everyone,
Today I tried to insert a pause into my print process. I’ve already searched the forum for my issue, but haven’t found a solution. Here’s the problem:
I can add a pause marker using the bar on the right (see image), but then I have to re-slice the object. When I re-slice, however, the pause marker disappears. Three months ago I was able to do this successfully, but today it absolutely won’t work.
After i hit "Slice now" Again, i get a message that the slicing process is canceld.
I tryed to add a pause one layer above, there its working fine. Why didn't it let me pause on this exact layer..
Could someone point me in the right direction?
PrusaSlicer Version: 2.9.2 Object: Multicolor print (two colors) Material: PLA Printer: XL
Thanks in advance for your help!
Postato : 28/06/2025 11:47 pm
1 persone hanno apprezzato
Eyvind Liljegren
(@eyvind-liljegren)
RE: After adding pause can't slice again
Exact same issue. Could not add pause at the desired layer, fine one layer above and one below. once a pause on a layer above is inserted a pause on the desired layer works fine, but if i remove the "shaperone" pause, the slicing fails again. Just updated to 2.9.4 because i noticed the problem i 2.9.3 and thought it might go away. Same issue in both.
Multicolor print, mk3s+ with mmu2s+ This workflow was flawless a few months ago.
Strange and unnecessary.
Postato : 09/12/2025 11:41 pm
