After adding pause can't slice again
Oliver Züllig
(@oliver-zullig)
Membre
Hey everyone,
Today I tried to insert a pause into my print process. I’ve already searched the forum for my issue, but haven’t found a solution. Here’s the problem:
I can add a pause marker using the bar on the right (see image), but then I have to re-slice the object. When I re-slice, however, the pause marker disappears. Three months ago I was able to do this successfully, but today it absolutely won’t work.
After i hit "Slice now" Again, i get a message that the slicing process is canceld.
I tryed to add a pause one layer above, there its working fine. Why didn't it let me pause on this exact layer..
Could someone point me in the right direction?
PrusaSlicer Version: 2.9.2 Object: Multicolor print (two colors) Material: PLA Printer: XL
Thanks in advance for your help!
Publié : 28/06/2025 11:47 pm
