A part of the object is not slicing
Why the steam image in the left is not slicing? I even increase the extrusion in Fusion 360 but nothing.
Best Answer by --:
The image consists of a wall that is less than the perimeter width. Enable Thin Wall Detection and it will slice correctly. Or, fix it in CAD by making the image thicker.
RE: A part of the object is not slicing
Does it the slicer tell you it needs to be repaired? Are there thin parts?
@cwbullet
nothing Can you see the file im trying to upload the 3mf but keep getting file type not allowed
@nocturno
You must zip it first!
3mf File for review
I just started a print to test this!
@cwbullet
Thank You!
So far so good. Well, I am getting a little problem with strings.
it's printing the steam icon even if it's not showing in the preview? interesting
As Tim posted above, Thin Wall Detection and it will slice. I was able to get this to print successfully with ASA and PLA. It should not be a problem.
@nocturno
Mine printed the steam icon and viewed it.
Thanks for all the help it worked!!!!
@nocturno
Great news!
