A part of the object is not slicing
[Rozwiązany] A part of the object is not slicing
Zilerd
(@zilerd)
Why the steam image in the left is not slicing? I even increase the extrusion in Fusion 360 but nothing.
Best Answer by --:
The image consists of a wall that is less than the perimeter width.  Enable Thin Wall Detection and it will slice correctly. Or, fix it in CAD by making the image thicker.
Opublikowany : 22/05/2021 9:04 pm
RE: A part of the object is not slicing
Does it the slicer tell you it needs to be repaired?  Are there thin parts?
Opublikowany : 22/05/2021 9:06 pm
Zilerd
(@zilerd)
@cwbullet
nothing Can you see the file im trying to upload the 3mf but keep getting file type not allowed
Opublikowany : 22/05/2021 9:08 pm
@nocturno
You must zip it first!
Opublikowany : 22/05/2021 9:19 pm
Zilerd
(@zilerd)
3mf File for review
Attachment removed
Opublikowany : 22/05/2021 9:25 pm
I just started a print to test this!
Opublikowany : 22/05/2021 9:43 pm
Zilerd
(@zilerd)
@cwbullet
Thank You!
Opublikowany : 22/05/2021 10:04 pm
So far so good.  Well, I am getting a little problem with strings.
Opublikowany : 22/05/2021 10:57 pm
Zilerd
(@zilerd)
it's printing the steam icon even if it's not showing in the preview? interesting
Opublikowany : 22/05/2021 10:59 pm
Opublikowany : 23/05/2021 6:20 am
As Tim posted above, Thin Wall Detection and it will slice.  I was able to get this to print successfully with ASA and PLA.  It should not be a problem.
Opublikowany : 23/05/2021 12:29 pm
1 ludzie polubili
@nocturno
Mine printed the steam icon and viewed it.
Opublikowany : 23/05/2021 12:30 pm
Zilerd
(@zilerd)
Thanks for all the help it worked!!!!
Opublikowany : 23/05/2021 1:59 pm
@nocturno
Great news!
Opublikowany : 23/05/2021 2:00 pm
