2.8.0 Can someone confirm this bug with minus key not working?
Leon
 Leon
(@leon-5)
Can someone confirm...
Are you unable to use the minus key anywhere in 2.8.0?
For example I am no longer able to put -.02 in the Z Offset field.  Nor am I am I able to type a "-" in the Custom GCode section.
My minus key works fine in other apps... and here as you can see.  (-)
Opublikowany : 15/07/2024 3:41 pm
RE: 2.8.0 Can someone confirm this bug with minus key not working?
Yes it is a bug.  Previous thread on here in this very forum about it.
Also reported several times on the PS github for example https://github.com/prusa3d/PrusaSlicer/issues/13043
If you want to check for existing issues then github is the place to go, their search function works pretty well.
Not the only input issue.  Depending on keyboard layout and language maybe but theres been reports of several keys not working.  Some only from the keypad etc.  Also the post processing field is borked once you enter something in there and want to edit it.  Cut and paste into a field still works so is the current workaround till its fixed.
Opublikowany : 15/07/2024 3:49 pm
1 ludzie polubili
