100% fill not efficient
m2tts
(@m2tts)
I have 100% fill set for a part, but the preview looks as if its trying to maintain wall thickness instead of just putting 100% fill in. This is doubling the moves the extruder is making to fill in the walls. I have the setting for "Ensure vertical shell thickness" unchecked which I thought was causing the problem.
Publié : 01/10/2020 9:36 pm
Membre
RE: 100% fill not efficient
You are right and despite popular belief, 100% infill does not mean solid.
Publié : 01/10/2020 10:14 pm
Nikolai
(@nikolai)
@mark-m30
Most likely the object geometry is causing this issue. You can try to re-mesh it (with meshmixer or similar tool).
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Publié : 01/10/2020 10:30 pm
m2tts
(@m2tts)
@nikolai-r
I don't see why it would be the geometry that is the issue, as clearly the slicer knows where the boundaries of the geometry are as seen in the perimeters being made. It looks to me as if the unchecked "Ensure Vertical Shell Thickness" is being ignored, otherwise, why wouldn't the infill go all the way across the inside instead of only halfway?
Publié : 01/10/2020 11:52 pm
Nikolai
(@nikolai)
@mark-m30
You might have verticies, edges, faces hidden in the object. Something you don’t see in the slicer. But during slicing they are being used. I’m not saying it does apply in this case but I’ve seen already pretty strange slices because of that issue.
Was just a suggestion what you might try.
Often linked posts:
Real Multi Material
Publié : 02/10/2020 12:00 am
m2tts
(@m2tts)
@nikolai-r
That is a good suggestion, no worries. I have checked the mesh and there are no interior surprises in it. I re-sliced it setting the bottom layers to 50 and now I get the expected behavior. I don't understand why 100% infill wouldn't do the same thing.
Publié : 02/10/2020 12:40 am
Area51
(@area51)
Membre
I think this is the same problem as discussed here: https://forum.prusa3d.com/forum/prusaslicer/avoid-solid-infill-near-sloping-walls/
PS likes to support sloped walls with wiggled infill.
Publié : 02/10/2020 10:30 am
Posted by: @area51
I agree with Area51, its a known problem, without anyway of turning it off currently as no setting changes the behaviour.
Publié : 02/10/2020 11:12 am
