Kde mohu získat slicer ve verzi 2.5
Jára
(@jara)
Mám nainstalován "PrusaSlicer-2.4.0+win32-202112211601"  a nikde nemohu najít verzi 2.5 pro Win32.
Pokud to není, tak bych si tuto verzi klidně zkompiloval a mohl bych ji publikovat pro ostatní uživatele.
Jakou verzí MSVC to mám kompilovat?
Jakou verzi knihovny boost mám použít?
SLIC3R_ASAN: OFF
SLIC3R_BUILD_SANDBOXES: OFF
SLIC3R_BUILD_TESTS: ON
SLIC3R_DESKTOP_INTEGRATION: ON
SLIC3R_ENABLE_FORMAT_STEP: ON
SLIC3R_FHS: OFF
SLIC3R_GTK: 2
SLIC3R_GUI: ON
SLIC3R_MSVC_COMPILE_PARALLEL: ON
SLIC3R_MSVC_PDB: ON
SLIC3R_PCH: ON
SLIC3R_PERL_XS: OFF
SLIC3R_PROFILE: OFF
SLIC3R_STATIC: ON
SLIC3R_WX_STABLE: OFF
SLIC3R_STATIC: ON
CMAKE_PREFIX_PATH: (default)
/Include//winrt/windows.graphics.printing3d.h was not found
STL fixing by the Netfabb service will not be compiled
Building without Win10 Netfabb STL fixing service support
CMake Warning at C:/Program Files/CMake/share/cmake-3.24/Modules/FindBoost.cmake:1384 (message): New Boost version may have incorrect or missing dependencies and imported targetsCall Stack (most recent call first): C:/Program Files/CMake/share/cmake-3.24/Modules/FindBoost.cmake:1507 (_Boost_COMPONENT_DEPENDENCIES) C:/Program Files/CMake/share/cmake-3.24/Modules/FindBoost.cmake:2118 (_Boost_MISSING_DEPENDENCIES) CMakeLists.txt:331 (find_package)
CMake Error at C:/Program Files/CMake/share/cmake-3.24/Modules/FindPackageHandleStandardArgs.cmake:230 (message): Could NOT find Boost (missing: system filesystem thread log locale regex chrono atomic date_time iostreams) (found suitable version "1.80.0", minimum required is "1.66.0")Call Stack (most recent call first): C:/Program Files/CMake/share/cmake-3.24/Modules/FindPackageHandleStandardArgs.cmake:594 (_FPHSA_FAILURE_MESSAGE) C:/Program Files/CMake/share/cmake-3.24/Modules/FindBoost.cmake:2376 (find_package_handle_standard_args) CMakeLists.txt:331 (find_package)
Configuring incomplete, errors occurred!
See also "O:/src/PrusaSlicer-version_2.5.0/build/CMakeFiles/CMakeOutput.log".
See also "O:/src/PrusaSlicer-version_2.5.0/build/CMakeFiles/CMakeError.log".
Veröffentlicht : 22/12/2022 2:23 pm
Jára
(@jara)
I attempt to follow build recommendation from file G:\PrusaSlicer-version_2.5.0\doc\"How to build - Windows.md"  and it also completelly fails.
Promiňte, tohle je české fórum. Následoval jsem přesně doporučení jak sestavit slicer pro Windows dle "How to build - Windows.md" a to také naprosto selhalo.
************************************************************************ Visual Studio 2019 Developer Command Prompt v16.0** Copyright (c) 2021 Microsoft Corporation**********************************************************************[vcvarsall.bat] Environment initialized for: 'x64'
C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional>cd c:\temp\PrusaSlicer
c:\temp\PrusaSlicer>build_win.bat -d "../PrusaSlicer-deps" -r consoleERROR: No Visual Studio installation found.
Performs initial build or rebuild of the app (build) and deps (build/deps).Default options are determined from build directories and system state.
Zkusil jsem x64 command prompt od Visual Studia 2019 a nic.
Diese r Beitrag wurde geändert Vor 3 years 2 mal von Jára
Veröffentlicht : 25/12/2022 12:38 am
