Hole orientation in Hollowing
Hi guys,
Can anyone tell me how to rotate the hole in the hollow tool?
This tool is so useful but it gives me some frustration. I have a hard time positioning the hole in the right position, especially since the hole is always positioned normal to the picked plane.
For example: if I select a position on a picture left then I get the orientation of the hole opposite to gravity (picture on right).
The best solution in my mind is if I had the possibility to manipulate (move, rotate or change) the hole after selecting its general position. In case of presented
drill hole, I could move it a little up and rotate the position of the end towards the build plate.
Best regard
Roman
Opublikowany : 15/05/2022 11:21 am
