What's your first CoreOne INDX print going to be?
David Wood (dwuk3d)
(@david-wood-dwuk3d)
I'm planning on doing this 11 colour, 9 plate print as my first test print.
I've split the model up so that the most colours on a single plate is 8 - so should work ok hopefully.
It's a 27hr print on a rival 7 nozzle printer - so hopefully a bit quicker on the CoreOne INDX.
https://www.printables.com/model/1720783-c1-indx-11-colour-test-print-po-cruises-aurora-150
Will probably also do the smaller version pictured as a single plate - but will either need to do a few manual filament swaps, or dust off the Palette2 and P2PP to do a small number of swaps.
Opublikowany : 14/05/2026 10:05 pm
RE: What's your first CoreOne INDX print going to be?
Something functional.
Opublikowany : 14/05/2026 10:37 pm
David Wood (dwuk3d)
RE: What's your first 8 colour CoreOne INDX print going to be?
Interesting.  I do most of my functional prints single colour - but the most recent one I did that is CoreOne related is this one - the screw sorter for the CoreOne build.
https://www.printables.com/model/1708083-core-one-organiser-remix
Opublikowany : 15/05/2026 5:30 am
It's not necessarily about colors. My first prints on the H2D were PETG with PLA support structures, and caps for illuminated pushbuttons with inlaid translucent lettering. I want to try PETG parts with integrated TPU seals next.
Opublikowany : 15/05/2026 5:49 am
David Wood (dwuk3d)
Agreed - I guess I should have titled the topic as What is your first CoreOne INDX 8 Nozzle print going to be - as I guess most of the functional printing - PLA / PETG support structure people will go for the 4 Nozzle version, or a U1.
Personally I have had IDEX's, multi gantry machines, H2D, H2C - but have never found I needed to do multi material support in the same print.  I've got loads of rolls of PVA  and PLA support material that I have never used.   The only one time I did multiple material support with TPU and PLA - on a single head printer.   I actually printed to support section first, then slotted it into the TPU print mid print.
I would like to try out the folded TPU approach done by Functional Print Friday at some point though.
Opublikowany : 15/05/2026 6:23 am
1 ludzie polubili
Right, I am definitely in the "multi material" camp, not "multi color". Had ordered the 4-tool INDX Founders Edition since I never expected to need 8, and then even fell back onto the H2D when I ran out of patience with Prusa and Bondtech.
Having an efficient way to print two materials should be enough for me most of the time -- although I can foresee some applications where I want three (two in the model, one for supports) and will end up with some wasteful AMS filament switching.
Opublikowany : 15/05/2026 6:32 am
mnentwig
(@mnentwig)
I didn't order one but my first prints would be with a "buyoff" mindset:
That is, e.g. a 20x20x0.2 mm chip per extruder, adjacent on one edge to confirm Z layer offsets are consistent and also sanity-check XY offset. The print takes a minute or two and I wouldn't expect issues. But surprises happen and it's much faster to debug here than on a model print.
Later, Orca's "volumetric flow rate test" with translucent PETG at high temperature: The surface finish shows when the material doesn't have enough time in the hot zone to melt completely, gives a ballpark number what the new hotend can manage.
Possibly also a tall "pie chart" with all colors and lowest layer height to check for issues with toolchanging. Much faster with a minimal print (toolchange time dominates) and obviously cheaper if something new is learned.
Opublikowany : 15/05/2026 6:45 am
David Wood (dwuk3d)
Probably should do a few of those calibration prints myself too - but my genuine first print after doing my H2D -> H2C upgrade (which I suspect is more complicated than the C1 -> C1 INDX upgrade) - was this 17.5 hr 8 colour ship print.   And it worked pretty much perfectly first time - so hope the C1 INDX upgrade works as well out of the box.
Opublikowany : 15/05/2026 6:59 am
2 ludzie polubili
I print a lot of ABS and PET with TPU as either gaskets or flex joints.  That is probably my favorite use of multimaterials.
Posted by: @jurgen-7
Opublikowany : 15/05/2026 10:12 am
1 ludzie polubili
