What's your first CoreOne INDX print going to be?
David Wood (dwuk3d)
(@david-wood-dwuk3d)
I'm planning on doing this 11 colour, 9 plate print as my first test print.
I've split the model up so that the most colours on a single plate is 8 - so should work ok hopefully.
It's a 27hr print on a rival 7 nozzle printer - so hopefully a bit quicker on the CoreOne INDX.
https://www.printables.com/model/1720783-c1-indx-11-colour-test-print-po-cruises-aurora-150
Will probably also do the smaller version pictured as a single plate - but will either need to do a few manual filament swaps, or dust off the Palette2 and P2PP to do a small number of swaps.
Posted : 14/05/2026 10:05 pm
RE: What's your first CoreOne INDX print going to be?
Something functional.
Posted : 14/05/2026 10:37 pm
David Wood (dwuk3d)
RE: What's your first 8 colour CoreOne INDX print going to be?
Interesting.  I do most of my functional prints single colour - but the most recent one I did that is CoreOne related is this one - the screw sorter for the CoreOne build.
https://www.printables.com/model/1708083-core-one-organiser-remix
Posted : 15/05/2026 5:30 am
It's not necessarily about colors. My first prints on the H2D were PETG with PLA support structures, and caps for illuminated pushbuttons with inlaid translucent lettering. I want to try PETG parts with integrated TPU seals next.
Posted : 15/05/2026 5:49 am
David Wood (dwuk3d)
Agreed - I guess I should have titled the topic as What is your first CoreOne INDX 8 Nozzle print going to be - as I guess most of the functional printing - PLA / PETG support structure people will go for the 4 Nozzle version, or a U1.
Personally I have had IDEX's, multi gantry machines, H2D, H2C - but have never found I needed to do multi material support in the same print.  I've got loads of rolls of PVA  and PLA support material that I have never used.   The only one time I did multiple material support with TPU and PLA - on a single head printer.   I actually printed to support section first, then slotted it into the TPU print mid print.
I would like to try out the folded TPU approach done by Functional Print Friday at some point though.
Posted : 15/05/2026 6:23 am
Right, I am definitely in the "multi material" camp, not "multi color". Had ordered the 4-tool INDX Founders Edition since I never expected to need 8, and then even fell back onto the H2D when I ran out of patience with Prusa and Bondtech.
Having an efficient way to print two materials should be enough for me most of the time -- although I can foresee some applications where I want three (two in the model, one for supports) and will end up with some wasteful AMS filament switching.
Posted : 15/05/2026 6:32 am
mnentwig
(@mnentwig)
I didn't order one but my first prints would be with a "buyoff" mindset:
That is, e.g. a 20x20x0.2 mm chip per extruder, adjacent on one edge to confirm Z layer offsets are consistent and also sanity-check XY offset. The print takes a minute or two and I wouldn't expect issues. But surprises happen and it's much faster to debug here than on a model print.
Later, Orca's "volumetric flow rate test" with translucent PETG at high temperature: The surface finish shows when the material doesn't have enough time in the hot zone to melt completely, gives a ballpark number what the new hotend can manage.
Possibly also a tall "pie chart" with all colors and lowest layer height to check for issues with toolchanging. Much faster with a minimal print (toolchange time dominates) and obviously cheaper if something new is learned.
Posted : 15/05/2026 6:45 am
David Wood (dwuk3d)
Probably should do a few of those calibration prints myself too - but my genuine first print after doing my H2D -> H2C upgrade (which I suspect is more complicated than the C1 -> C1 INDX upgrade) - was this 17.5 hr 8 colour ship print.   And it worked pretty much perfectly first time - so hope the C1 INDX upgrade works as well out of the box.
Posted : 15/05/2026 6:59 am
I print a lot of ABS and PET with TPU as either gaskets or flex joints.  That is probably my favorite use of multimaterials.
Posted by: @jurgen-7
Posted : 15/05/2026 10:12 am
David Wood (dwuk3d)
Pre testing of my first C1INDX print now complete, plus C1 printer build now about 50% complete.
This post was modified 1 month ago by David Wood (dwuk3d)
Posted : 16/05/2026 3:41 pm
Paffendorf
(@paffendorf)
I believe that the biggest advantage of the INDX isn't printing in multiple colors; the real benefit is being able to increase the print speed for very large parts. For example, you can use a 0.4mm nozzle for the perimeters when printing with PCCF or an expensive material, but print the infill with much cheaper PLA using a 0.8mm nozzle. That, in my opinion, is the benefit of this system.
Posted : 18/05/2026 4:56 pm
Posted by: @paffendorf
That's assuming PrusaSlicer will support this. There was a proof-of-concept awhile back for the XL. It could probably be resurrected. I'm curious what will be in the PrusaSlicer 3.0 release (whenever that is...)
Posted : 18/05/2026 5:02 pm
Paffendorf
(@paffendorf)
I read somewhere that in PrusaSlicer 3.0, you’ll be able to choose which nozzle to use for infills and which for perimeters. I understand that when you configure the nozzles, you’ll specify their sizes, and the program itself will calculate how many perimeters you need for every 0.8 mm of infill. In other words, there will be fewer nozzle changes.
Posted : 18/05/2026 5:06 pm
Take this for what it is worth:
https://www.fabbaloo.com/news/prusaslicer-3-0-could-arrive-within-weeks-following-extensive-code-overhaul
There are also multiple posts hinting at a coming announcement in the next couple of weeks.  That could also be an announcement of a delay.
Posted by: @hyiger
Posted : 18/05/2026 5:13 pm
Posted by: @cwbullet
My opinion is the public beta will be announced and dropped at the same time. When though is anyone's guess...
Posted : 18/05/2026 6:08 pm
It is all conjecture but I think we will hear something in a few weeks.
Posted by: @hyiger
Posted : 18/05/2026 7:03 pm
Same Old Shane
(@same-old-shane)
Member Admin
I am dying to do this model, but do it in a Evangelion unit 02 color scheme as I did his mecha godzilla model in evangelion unit 01 colors previously
Mecha King Kong
Shane (AKA FromPrusa)
Posted : 19/05/2026 1:33 am
David Wood (dwuk3d)
My CoreOne build now complete - ready for adding INDX - updated this remix of Petr Bojar's Core One Organiser with a picture showing parts left over after end of build, plus list of comments I have on the design and build if it is of any interest to anyone else who hasn't used Prusa for a while, and are building a C1 for INDX.
Started printing the single colour parts of my first INDX test print for familiarisation.
Posted : 19/05/2026 6:42 am
