Which nozzle for the Core One L?
Why aren't the nozzles compatible with the Core One L and the Core One the same?
Is the Nextextruder different for the Core One than for the Core One L?
Thanks
RE: Which nozzle for the Core One L?
I wouldn't base the lack of info on the site as a basis for determining what is not compatible. The nozzles should all work, as it is the same nextruder. I'll know for sure if they ever decide to ship my C1L.
Core One L MMU3, MK3S
The nozzles are most definitely compatible between the Core One and Core One L. It's the exact same Nextruder.
On the Prusa website, in the nozzles section, if you look at the filters by model, you'll see that there are 17 types available for the Core One and 7 for the Core One L. If they were compatible, shouldn't the number be the same?
Hi Pedro,
Thanks
I asked this same question from Prusa Support yesterday. They were also surprised as indeed both printers use the same Nextruder hardware so all nozzles should be compatible.
According to Support, this is most likely a temporary issue in the shop; they have escalated internally so I expect that the listings will be updated to include C1L for all Nextruder nozzles.
I am using my obsidian nozzle from mk4s hat no issue
