Nozzle Crash - New pre assembled Core one L
[Solved] Nozzle Crash - New pre assembled Core one L
maxluzi
(@maxluzi)
Hi everyone,
My new Core One L had been printing for a few days. I experienced some warping with ASA, but otherwise, everything was good. I only use Prusament! Last night, I installed the 0.6mm nozzle (having printed the specific tool for it before), and this morning I woke up to what you see in the photos.
I’m trying to figure out if I did something wrong. I made sure to update the nozzle diameter to 0.6mm in the printer’s settings menu as well as in the slicer. It’s pretty 🤮 to have this happen to such a new machine... I’d be very grateful for any hints or advice.
I’m not new to 3D printing; I’ve been running an MK3S since 2021, which prints parts for our workshop and production almost continuously.
Greetz from Germany
Napsal : 18/01/2026 9:24 am
maxluzi
(@maxluzi)
RE: Nozzle Crash - New pre assembled Core one L
Sorry, here are the pictures
Napsal : 18/01/2026 10:04 am
It looks like the nozzle retaining screws were not tightened properly allowing the whole nozzle/heater assemble to slide out of the extruder housing!
Napsal : 18/01/2026 10:37 am
2 lidem se líbí
maxluzi
(@maxluzi)
Hey, thanks for the answer. It was my fault. I didn't fix the nozzle properly... I wish there would be a manual for this in the printer's manual! It's essential that you slightly tighten the nozzle and then move it up and down a little until the screws are snapping in the two nuts...
After all, some ASA was stuck inside the extruder, and I had to disassemble it. Now everything seems to be ok. We use our printer for parts in our workshop, so i needs to be very accurate. Actually, I'm printing some tests.
Napsal : 18/01/2026 3:26 pm
Ruebarb
(@ruebarb)
Hope Prusa support fixes the issue, be prepared to wait.......... I also came from a problem free dependable Mk3S (Still is), the Core one L prints very well, but it is riddled software issues. And assembly issues seems to be common from factory. I feel like Prusa didn't test this printer at all in the real world, the amount of obvious issue that should have been addressed is long and growing.
Core One L MMU3, MK3S
Napsal : 18/01/2026 3:30 pm
1 lidem se líbí
