Single Extruder Multi Material prints not working for me
cschalle
(@cschalle)
So I got some items with numbers on them and I want the numbers to be using a different color for the last layer. I assume Single Extruder Multi Material should help me do this.
So I import my STL file and then go into 'Printers' in PrusaSlicer. There I chose 2 extruders and click the Single Extruder Multi Material option. Then I go into each extruder and choose 2 different colors.
Then back in the plater I choose the multimaterial painting tool and then use tool type smartfil to paint the numbers using extruder color 2.
Then I use prusaconnect to send the print to my CoreOne. So what I would expect to happen is that it stops before the final layer and lets me change filament. Instead it just finishes the print using the single filament.
Am I doing something wrong or not understanding how this feature is supposed to work?
Postato : 07/07/2025 1:09 am
RE: Single Extruder Multi Material prints not working for me
do you have an MMU3 installed on your core one?
Have you enabled a wipe tower?
if you don't have an MMU installed, have you added    M600   to the Custom Gcode Toolchange Gcode dialog box?
this will caise a filament chaange at the start of the print job, and a filament change where you want it before the last layer colour change area
Postato : 07/07/2025 7:06 am
cschalle
(@cschalle)
No MMU3, once I turn on the "Single Extruder Multi Material " option the wipetower does automatically appear on my print, so it is print that.
I try that M600 code, so thank you!
Postato : 07/07/2025 12:08 pm
cschalle
(@cschalle)
Thank you this worked, although I did get an extra filament change before and after print in addition to the actual one at color change. I do notice that the M600 code was already in the G-code under the 'Color Change G-code' section, but I guess it is being ignored there for some reason. Seems like a bug I should file with Prusa.
Postato : 07/07/2025 1:13 pm
cschalle
(@cschalle)
Created this Prusa Slicer bug report: https://github.com/prusa3d/PrusaSlicer/issues/14694
Postato : 07/07/2025 2:41 pm
Ckobar
(@ckobar)
You have to put this code to the "toolchange" section
{if layer_num >= 0}M600 ; change to filament for extruder {next_extruder + 1}{endif}{if layer_num >= 0}M600 ; change to filament for extruder {next_extruder + 1}{endif}
Postato : 08/07/2025 11:46 am
cschalle
(@cschalle)
Thank you that works like a charm! Much appreciated. Am I right though that Prusa Slicer should do this automatically for me when I choose multifilament printing and that it doesn't is a bug? Or is multifilament printing considered such an advanced option that I should expect to do GCode scripts myself?
Postato : 08/07/2025 2:43 pm
