Print keeps Failing halfway through Core One with MMU3
ddecoste38135
(@ddecoste38135)
So I have a small print but it has 2 colors.  (6 Dice)   I get good bed adhesion but then it fails about halfway through.   I have also had layer shifting about the same area.   I have looked at a few things but I am fairly new to this and I do not know what I should be looking for.   I think I will try the belt adjustment tomorrow.   I have slowed the printing down but I am not sure what else to try.  I will take some pictures tomorrow.
Napsal : 21/09/2025 3:14 am
ddecoste38135
(@ddecoste38135)
RE: Print keeps Failing halfway through Core One with MMU3
This is the first layer. Should the print have the spots where the nozzle is picked up?
Napsal : 21/09/2025 3:10 pm
ddecoste38135
(@ddecoste38135)
The next 2 are a few layers later.
I have my concerns about the wipe tower.   More to come.
Napsal : 21/09/2025 3:19 pm
ddecoste38135
(@ddecoste38135)
So I was able to just see the failure.   I looks like a collision on the purge block.   If you look at the back of black it has built up.  I will try tuning the belts and then moving the purge block
Napsal : 21/09/2025 4:32 pm
1 lidem se líbí
