Filament sensors disabled error
Phil
 Phil
(@phil-15)
I printed a small gridfinity box in PLA. It had trouble in the middle of the print. The C1 stopped and asked me to change filaments (this is a single color print job). I didn't know the issue so I changed to a different PLA spool and continued. At the end of the job C1 told me the filament sensors are disabled. I followed these instructions, and I blew out the hole while running filament in and out. I then went and loaded/unloaded filament thru the menu and purged. It worked as normal. How can I be sure the sensors are working again?
https://help.prusa3d.com/article/nextruder-filament-sensor-core-one-core-one-l-mk4-s-mk3-9-s-xl_465702
Prusa Core One
Napsal : 27/01/2026 5:48 pm
Phil
 Phil
(@phil-15)
RE: Filament sensors disabled error
BTW, I think the problem was caused by filament binding on the spool. I noticed it was binding when I started the job, but I thought I fixed it on the spool.
Prusa Core One
Napsal : 27/01/2026 5:50 pm
Posted by: @phil-16
Go to "Control > Calibration & tests > 11 Filament sensor calibration", and follow the on-screen procedure. It has you remove and then re-insert the filament, confirms that the sensors work and determines the correct thresholds for the sensor states.
Napsal : 27/01/2026 6:22 pm
1 lidem se líbí
Phil
 Phil
(@phil-15)
DOH! Why didn’t I think of that?  thank you
Posted by: @jurgen-7
Posted by: @phil-16
Prusa Core One
Napsal : 27/01/2026 6:34 pm
Geoff Steele
(@geoff-steele)
FWIW after something similar happened to me I found it handy to have both filament sensors added to the info in the footer of my screen (Settings/User Interface/Footer)
On there I have nozzle, bed, and chamber temps, and both those.
Cheers, Geoff
Napsal : 27/01/2026 9:56 pm
