Worse prints and more noise after accelerometer calibration?
Andersson
(@andersson)
Okay I can't say for sure that the prints are worse as I think this is the only part where it's been noticeable, but it's making more noise now I'm certain.
I didn't really have any issues with my kit-built Core One previously. The only thing would be that when printing during the night, there were some vibrations that annoyed me too much to fall asleep in another room even when it ran on stealth mode. I later found that it was the non-print travel at 350mm/s that created those noises, so I decreased that to like 120-150 when I knew that I would print at night.
Anyway I had read that the accelerometer and the calibrations could make it even more quiet and perhaps make the prints even better.
I received the accelerometer and the lubrication set for the linear rail, put in a little grease into the carriage. Then I made sure the belts were tightened correctly and installed the accelerometer and ran the input shaper and phase stepping.
After this I printed a benchy and it felt almost like the printer was a little quieter, couldn't say that print quality changed at all when comparing though.
after a few days I was printing some other stuff and certain motion was really loud every now and then, also these circular parts came out with wavy outer walls that I can even feel by hand. I compared to another object from a few months ago in the same white PLA that had larger round corners and they looked great, nothing like this.
What to do think could cause this and do you have any suggestions what to do first? I was thinking I'd check the belts again, maybe clean and lubricate the Y rods, run the calibrations again with the accelerometer. I just wanted to hear if you've heard these noises before and knew what to look for.
Here are a few pictures of how these new prints came out:
And here's a video of the loud noises that I have never heard before, the only change I've done recently is running the calibrations with the accelerometer.
Thank you in advance!
Publié : 23/02/2026 7:37 pm
Samael
(@samael)
RE: Worse prints and more noise after accelerometer calibration?
Hey, i am having similar issues but cant say if its the input shapping to blame.
I also did more or less what you did for servicing the device, was quite happy for a couple of weeks and then the noises started, similar to yours.
Its very specific and motion related, some prints are totaly smooth and quiet, others are just like your video....
VFAs are quite bad, will post an image of the latest prints when i go back home.
Belts are tightened, but i will try a new head calibration to see if it changes anything, maybe i swapped nozzles and it doesnt like it?
I also have a loose back left pulley, for some reason it can go up and down by 1mm maybe and i cant tighten it, like the screw threads are not catching at all.
Publié : 27/02/2026 2:45 pm
1 personnes ont aimé
Samael
(@samael)
These are my findings after printing a VFA tower, best results are with faster speeds, but when the model has to slow down, there is not much we can do about it...
Best VFAs performance at 340mm/s, 27.2mm3/s i think, in all axis, worst VFAs 300mm/s, 24mm3/s
Info on how to read the results: https://www.obico.io/blog/speed-test-in-orcaslicer-vfa-a-comprehensive-guide/#analyzing-the-speed-test-results
Regarding the noise:
About 200mm/s
About 240mm/s
About 480mm/s
As you can hear the noise levels are variable depending on both speed and axis, would love to have more people share their results so we can compare and maybe troubleshoot.
Publié : 01/03/2026 11:07 am
Andersson
(@andersson)
I loosened my belts all the way and checked that the gantry was square, cleaned the Y smooth rods and put on some new grease. I then tightened the belts again but this time with the belt tuning wizard instead of the app which I've only used before. The belts didn't get as tight as when I did it with the phone app, I think around 90-92hz and it said that it was good. I also tried what is suggested here: Link. Then ran the calibrations again with the accelerometer.
It's better again now, I don't know what happened and why it got so loud before. Maybe it's not perfect now either but definitely better.
Publié : 02/03/2026 6:55 pm
Samael
(@samael)
Will have a look at the linear rails as well then, thanks for the link!
Publié : 05/03/2026 11:01 am
Samael
(@samael)
Did not make any noticable difference in my case after all, will leave it as is as long as it moans but prints ok...
Publié : 09/03/2026 1:54 pm
abmantis
(@abmantis)
6.5.3 fixed a bug where input shaping was being applied to the wrong axis. You can try the beta to see if it improves the print quality issues: https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/6-5-3-beta-firmware-for-prusacore-one/
Regarding noise, one thing I think improved it on mine was making sure the gantry does not skew when applying tension to the belts. What I do is:
  1. loosen the belts completely (but without removing the tension screws, just making the belts loose)
  2. move the print head to the middle and to the front of the printer.
  3. check if both left and right sides of the gantry touch the ends. if not, twist the gantry so that it does (I had to do it initially). If the belts have a bit of tension, you may need to hold the print head gently against the front (but be very gentle, otherwise you will "override" the skew).
  4. start tensioning the screws, alternating 1/2 a turn on each side.
  5. when the belts start to get a bit of tension, check for play on the sides (like you did on on step 3). If one of the sides hits but the other has a bit of play (even if just a tinny tinny bit), loosen the screw on the opposite side (the one with no play) in small steps, until there is no play again. It is very important that there is really no play.
  6. when there is no play, continue tightening the belts. if they seem to have a normal tension, start the tension wizard (either the phone one or the built-in one).
Publié : 10/03/2026 11:47 pm
Samael
(@samael)
An update on the matter.
Not sure with what i am more shocked, seems like the issue we had was a firmware mess all along, took them a year to find out but here we are...
Old shapers values where MZV 47hz in X and ZVD 55hz, after the latest FW update 6.5.3 ran the calibration again, new values are ZVD 57hz and ZVD 56hz respectively.
Phase stepping calmed 87% and 89% vibration reduction!!
And guess what, not only the machine now actually runs MUCH more quite, but the VFAs are also almost gone in most speeds!!
Shocking difference, hard to capture it accurately in a picture but i think the results are evident even so...
Old test:
New Test:
Publié : 29/03/2026 7:17 pm
Andersson
(@andersson)
That sounds very promising, I’ll have to update and calibrate again and see if it makes a difference for me too!
Thanks I didn’t know there was new firmware, haven’t used the printer for a little while.
Publié : 29/03/2026 7:41 pm
Conrad
(@conrad-2)
After accelerometer calibration my printer is vastly quieter than before. I can't say if print quality is better as I tend to change filaments often and do completely different types of parts. In all honesty I think some unsolved mysteries remain. VFAs are about gone but appear for short distances. It's hard to believe different Core Ones would have resonant frequencies that differ by ten hertz, or that both axes are about the same. I get 47&47 fairly consistently. The stepping utility claimed my motors improved by almost 90%. I wish it provided some numbers and the ability to change them for that test.
Publié : 29/03/2026 9:55 pm
