How do we setup PrUSA Link to our Prusa Slicer?
NickAtNight
(@nickatnight)
It seems that PRUSA Connect is down this morning. So I cannot use that route to drop my file on my printer from Prusa Slicer.
I realized that I had never setup PRUSA Link on my Computer (only on my phone)... {{and I have to recover all my LinkSys logins first, cause I had not reset those since I got the new computer}}
So in Prusa slicers, we go to Prusa Connect, then we  Select a printer, then setup a printer.
(getting a string did not match the expected pattern if I put in SN*******)
Now it wants a Code.
   - Where do we get the code and what is the format (presumably from the silver tag on the back of the machine)
Dieses Thema wurde geändert Vor 14 hours von NickAtNight
Veröffentlicht : 13/12/2025 8:01 pm
RE: How do we setup PrUSA Link to our Prusa Slicer?
I'm not in front of my printer, but you should be able to get the API code from the firmware in UI. Probably under network settings. Prusa Connect is working for me so getting the API key from there is usually easier.
Veröffentlicht : 13/12/2025 8:22 pm
