Hardened nozzle tip broke off during printing
jarmund
(@jarmund)
I was printing a rather mundane PETG print earlier today, one I've printed plenty of times before, and I watch keeping an eye on the camera as the print was almost completed.
But then I see the print sheet being slid and lifted off the heat bed, with the print stuck to both the nozzle and the heatbed.
I stopped the print as quickly as I could, and started removing the PETG blob that had started to form around the nozzle, which was easy enough, since the plastic was still hot. However, that's when I noticed that this wasn't a normal blob of nozzle snot: The actual tip of the nozzle was missing, causing the extruded PETG to come out in a shape similar to that of toothpaste.
I wish I knew where the tip went - I probably lost it down the drain in this repurposed bathroom, as I wasn't aware of it being AWOL when I removed the print and printsheet. It's not in the print, and it isn't in the printer.
I've now changed back to the original brass nozzle that came with the printer, and it's printing just fine.
Any chance this is a manufacturing defect in the nozzle? It was a Prusa Hardened Nozzle (Nickel plated) 0.4mm, and I've been using it for less than a month (Part of Order No. 1764450524). I've had no issues with it until now, and it was in good condition and hasn't experienced anything that would've damaged it.
Either way I'd love some insight into what could've happened, so that I can prevent this from happening in the future.
Opublikowany : 25/01/2026 8:21 pm
jarmund
(@jarmund)
RE: Hardened nozzle tip broke off during printing
In this picture:
- The broken nozzle itself, serial number visible
- Original nozzle packaging
- The print it was working on (that groove is where it had clumped together when failing)
- A cat named Rhea
Opublikowany : 25/01/2026 8:30 pm
mnentwig
(@mnentwig)
sounds like a warranty case but you should bring this up with support, not this (user-to-user) forum.
Opublikowany : 25/01/2026 9:12 pm
1 ludzie polubili
jarmund
(@jarmund)
Emailed them, referring to this post. I was hoping that the community might have some insights, as I do not rule out other factors for this failure mode.
Opublikowany : 25/01/2026 9:38 pm
JustMe3D
(@justme3d)
Had the tip of my E3D V6 ObXidian hardened nozzle come off recently after estimated 30 hours of total use. The tip is just pressed into the main body so I believe this an issue of different reaction to heat by the two different materials.
This post was modified 3 months temu by JustMe3D
Opublikowany : 26/01/2026 12:32 am
Tommy_Prusa3D CM
(@tommy_prusa3d-cm)
Member Admin
Hey. Did you possibly have a clog in the past that you fixed by applying direct heat to the nozzle? Heating it like that might damage the fitting, and is one of the few situations where this could fall apart like this outside of some odd defect
Opublikowany : 26/01/2026 7:44 am
jarmund
(@jarmund)
Nope. No external heat has been applied.
Opublikowany : 26/01/2026 7:46 am
k1mu
 k1mu
(@k1mu)
My experience with trying to communicate with Prusa Support via e-mail wasn't great.  I know it's a pain, but you're far better off with the online chat. They're much more responsive and this can save you days to weeks of back-and-forth.
Opublikowany : 27/01/2026 2:38 am
D1g1talS0ul
(@d1g1tals0ul)
Same thing happened to me.  Nozzle was around 3 weeks old and never clogged. Then it sheered off while removing it.
Opublikowany : 11/03/2026 1:42 am
Tommy_Prusa3D CM
(@tommy_prusa3d-cm)
Member Admin
Definitely report to support and they can help you out. They will specifically need the serial number on the nozzle tube though so if you can include that it would go much faster.
Opublikowany : 13/03/2026 8:34 am
Artur5
(@artur5)
This problem is one of the drawbacks of composite nozzles were the tip is just inserted into the main body. Of course if they did it right, the issue would be very rare on nozzles practically new , but is no secret that nowadays Prusa's quality control isn't exactly top notch, to put it mildly.
Opublikowany : 13/03/2026 9:55 am
