Gcode for Chamber Fans and LED Light
PCR
 PCR
(@pcr)
Is there any Gcode where i can set the Chamber fans ? I dont want to use the temperature feature. Same for the LED lights?
Respondido : 10/02/2025 12:06 am
I understand that the fan in the XL enclosure is controlled via the regular M106 command [ https://marlinfw.org/docs/gcode/M106.html ] with fan index 3. Didn't see a specific reference to the Core One in the respective source code on the Prusa Github, so I would assume it's the same.
For the chamber lights, it's probably M355 [ https://marlinfw.org/docs/gcode/M355.html ] and for the colored LED bar M150 [ https://marlinfw.org/docs/gcode/M150.html ]
Respondido : 10/02/2025 7:39 am
gb160
(@gb160)
RE: Gcode for Chamber Fans and LED Light
Anyone got anymore info on this wrt the RGB bar , or the case LEDs?
M150 B255 S0
This turns the RGB bar off
M150 B255 S1
This turn the rgb bar blue
Cant really do anything else.
Respondido : 16/11/2025 10:01 am
ssmith
(@ssmith)
This page has info, haven't tried it though.
Respondido : 16/11/2025 7:06 pm
gb160
(@gb160)
Posted by: @ssmith
Yeah I don't think any of it is implemented properly.
I can turn the RGB bar blue or off only.
And the white light strip can just momentarily turn it off but it comes straight back on.
Respondido : 18/11/2025 4:23 pm
