Gcode for Chamber Fans and LED Light
PCR
 PCR
(@pcr)
Is there any Gcode where i can set the Chamber fans ? I dont want to use the temperature feature. Same for the LED lights?
Posted : 10/02/2025 12:06 am
I understand that the fan in the XL enclosure is controlled via the regular M106 command [ https://marlinfw.org/docs/gcode/M106.html ] with fan index 3. Didn't see a specific reference to the Core One in the respective source code on the Prusa Github, so I would assume it's the same.
For the chamber lights, it's probably M355 [ https://marlinfw.org/docs/gcode/M355.html ] and for the colored LED bar M150 [ https://marlinfw.org/docs/gcode/M150.html ]
Posted : 10/02/2025 7:39 am
