False Replace Filament Alarm
mike
 mike
(@mike-60)
Two print jobs now (on my Core One) have resulted in a replace filament warning and subsequent stoppage of a print.  Both times at approximately 98% completion (4 hours 48 minutes into the print job).
In both cases there was lots of filament on the spool, and no issues with it moving freely.  Both prints used Spectrum Filament FlameGuard ASA 275.
Why is this issue occurring?  I recalibrated the filament sensor before this last print and it still reported an out of filament alarm.  Do I need to disable the filament sensors now?  This is annoying, I shouldn't have to worry about this unless it is a real issue.
Best Answer by FoxRun3D:
A quite common reason for unexpected filament changes is an accidentally inserted filament change in the slicer by inadvertently clicking on the slider in the slicer preview. Your observation that it happens at the same time in the print makes me suspect that is more likely the cause of error than a mechanical issue.
Respondido : 22/06/2025 9:05 pm
mike
 mike
(@mike-60)
RE: False Replace Filament Alarm
Since I'm now on my phone I can't edit the original post.   Another question, how does this sensor work?   Is this a photo sensor or a limit switch?   If it's the later, how has it been mechanically integrated that it detects filament?  If it's an optical sensor, what kind of sensor is it?
Respondido : 22/06/2025 9:26 pm
Posted by: @mike-60
It is ultimately a photo sensor, but it does not sense the optical properties of the filament. The filament pushes against a steel ball, which in turn pushes a little lever, which inserts a black flag at its other end into a forked light sensor.
In this direction, it's all forced displacement, so it's hard to see how the mechanical part could fail. (If the lever were to jam, the ball should block the filament path and make inserting filament impossible.) A fault in the optical sensor or the wiring is more likely.
Unfortunately the side filament sensor is a bit awkward to get to. If you have purchased your printer as an assembled unit, I would let Prusa support deal with this.
Respondido : 22/06/2025 10:12 pm
mike
 mike
(@mike-60)
Wow, overly complicated.   A simple micro switch would accomplish the same thing and be less complicated.  Make a cam mechanism to drive the micro switch.
I'm leaning towards a QC issue with the filament, as it's only with this brand I've had an issue with.   I'll try another brand and see if the issue carries over.   But I find it's also interesting that it's at the exact same time in the print that the issue occurs...hmmmmm
Respondido : 22/06/2025 10:22 pm
Respondido : 23/06/2025 12:38 pm
2 les gusta
mike
 mike
(@mike-60)
Thanks, I will check this out later in the week and report back.
Respondido : 24/06/2025 12:41 am
mike
 mike
(@mike-60)
You are correct.  I accidentally added a filament color change just before the very top layer.  Thanks for pointing this out as a likely scenario.
Respondido : 25/06/2025 10:28 pm
3 les gusta
tonyPA
(@tonypa)
Miembro
I've seen this a couple times and never intentionally added a filament change. Should be harder to do.
Respondido : 12/09/2025 5:50 pm
bapski
(@bapski)
this just happened to me in my last print(or two) i couldn't recall if the occurrence was before or after i updated my XL firmware.
MY MODELS AT PRINTABLES
Respondido : 12/09/2025 7:29 pm
Skylar31
(@skylar31)
Miembro
The solution from FoxRun3D is spot on!
Since it happened at the exact same time in both prints, it was almost certainly the accidental filament change inserted in the slicer preview—that slider is way too easy to click by mistake.
You can also try this tool for free. https://onlinealarm.co/
Respondido : 23/10/2025 12:48 pm
mnentwig
(@mnentwig)
 Maybe related, I got "Filament Ejected" error with MMU-modified sensor with gyroid infill, most likely from heavier vibrations.
This was fixed (at least I hope it is ...) by tightening the two screws on the extruder for the idler springs.
Respondido : 23/10/2025 6:11 pm
Bram
 Bram
(@bram-2)
Miembro
I'm seeing this a lot lately, the gcode viewer does not show extra filament changes added. Another suggestion from https://forum.prusa3d.com/forum/prusaslicer/prints-randomly-force-a-filament-change-mid-print/ is that the filament sensor might be misbehaving.
Respondido : 24/11/2025 10:16 am
