Core One screams. Don't know why.
JPMath
(@jpmath)
Hello.
Just think the problem is in the XY gantry since I checked everything else.
See this video...
Video of a printer going into resonance
Posted : 12/01/2026 11:46 pm
RE: Core One screams. Don't know why.
I only see a still photo?
Some background information would be helpful too. Is this a kit or a factory-assembled printer? Has it always done this, or is it a new behavior that has suddenly set in? Does it print ok while "screaming", or does one of the motion axes stop due to step loss?
Posted : 13/01/2026 6:33 am
jan.d.slay
(@jan-d-slay)
As Jürgen already said, some information would be very helpful!
Even though I don't know what the noise sounds like, I can understand what you mean.After assembling my conversion kit, I also had noises when the X/Y axis moved.It got noticeably better (unfortunately not gone yet) when I tightened all the screws on the Nextruder and the XY axis.The print head is probably vibrating and transferring that to the housing.
What kind of surface is your printer standing on?
My printables
Prusa XL - Quick Start Gcode
Posted : 13/01/2026 6:53 am
JPMath
(@jpmath)
https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/01/52db3089-pxl_20260112_233644175.ts_.mp4
Sorry for the first post without video!
Not sure if it will work this time.
Anyway, this happens at 15 - 16s on this video (if you see it).
I did see some people having solving such problems here by loosening linear bearings and doing belt calibration again.
Will give it a shot this weekend.
This post was modified 20 hours ago by JoanTabb
Posted : 14/01/2026 1:09 pm
JPMath
(@jpmath)
Happens at ~ 15-16s...
It is a kit. It was upgraded to Core One +.
Did not do any noise for 4 months.
Stands on a sturdy 3cm thick plank of wood, fixed to the wall and the underneath furniture.
Belt were retensonned and accelerometer used to calibrate IS.
Posted : 14/01/2026 1:48 pm
Posted by: @jpmath
Have you run the phase stepping calibration? That should reduce a lot of the noise (it did for me)
Posted : 14/01/2026 4:30 pm
Posted by: @jpmath
Strange -- your post did still not show a video, but quoting it reveals the link. So I have watched it now. 👍
I would not call that noise "screaming". It is just some part that vibrates, excited by a certain stepper motor frequency. Maybe a screw has come loose somewhere. Certainly nothing dramatic.
However, the source of such resonances is hard to locate. You can try and touch various parts of the printer while the resonance occurs, to see whether that dampens the sound. Or just go around and check whether the screws are still tight: The various M3 screws on the print head, the gantry mounting brackets, the stepper motors, and the mounting blocks for the Y rails are good starting points, I think.
Posted : 14/01/2026 4:38 pm
Hi JPMath,
the reason your video's are not showing, is because there is some formatting information surrounding the link address
See image below
I deleted the formatting data, and the link is now visible
