Can't remove PTFE tube from extruder
Łukasz Kostka
(@lukasz-kostka)
Hi
I had some difficulty feeding Fiberology FiberFlex filament into hotted. Since I couldn't push it past filament sensor, I had to unscrew PTFE socket/mount (however it's called. marked with red arrow) and push it manually. Stuck at filament sensor. I've tried pushing black collar as well as pulling it (I don't remember which direction releases is). No luck. Is it one time use part ? Any replacements available ?
Opublikowany : 15/05/2026 5:18 pm
Conrad
(@conrad-2)
RE: Can't remove PTFE tube from extruder
Push the black ring. It may help to use a small wrench to get pressure on several sides. Some have suggested the Prusa multi-wrench, if you have one. The part can be used many times- nothing should wear out.
Opublikowany : 15/05/2026 10:06 pm
1 ludzie polubili
mnentwig
(@mnentwig)
It's counterintuitive but the PTFE tube may be easier to pull out if you push it in first, together with the ring.
Those pneumatic couplings are industrial equipment used out of context, if you will, on a printhead with a few microns tolerance otherwise.
Opublikowany : 15/05/2026 10:32 pm
2 ludzie polubili
Łukasz Kostka
(@lukasz-kostka)
Thx. I will try your solutions. Maybe there is some other fitting that isn’t so tight.
Opublikowany : 16/05/2026 11:18 am
