Bug when pausing print and changing settings after Filament Chance
Do the following to recreate the issue:
- Add a Pause to your GCODE. In my case that was a filament change. As i've switched filament type, not just color ive used the pause for it. Let the Pause be long enough, to turn off heating (I think its >30 min)
- After this time, switch the filament
- Upon loading the new filament, Change the nozzle temp. the Printer will not let you do that. It only enables the tune button when the pause is continued. But you can use the Android app to force a different temp upon the nozzle.
- The printer will now go for the new nozzle temp, to continue the print. After reaching it though, it never continues. It never is able to finish the heating process, i guess because we switched the heating temp its waiting for.
- To resolve the issue, select cooldown nozzle from the app. The printer will continue. Stting temp to the previusly used temp also doesnt work.
- As soon as youve hit cooldown and the printer unparks, hit the new Temp you want to print at to avoid cold extrusion.
I am aware that using the app to force temp is not meant to be. But either block it in the app, or give the user a way to switch filament type, not just color.
Thats it, any questions, feel free
Postato : 02/07/2025 4:32 pm
