BuddyCam alternatives
Gerf Derp
(@gerf-derp)
Does anyone know if you can flash the buddy cam to be a plain RTSP camera? I like that it is built to fit the enclosure perfectly, but I have no use for Prusa Connect and would rather use octoprint.
If not that, what are some good cameras to live in the enclosure? I have a raspicam 2.0 in my Lack enclosure which runs fine even when printing ASA. But the gaps in the acrylic panels allow the ribbon cable to pass through perfectly. I only saw a narrow, round hole for the buddy cam usb cable.
Can you tell I have another six weeks to wait for my delivery but I'm going to spend every day thinking about customizing it anyway?
Posted : 03/02/2025 6:54 pm
emoses
(@emoses)
RE: BuddyCam alternatives
I made this mount for the C920 I had sitting around: https://www.printables.com/model/1196763-core-one-camera-mount-for-logitech-c920c930
I had to snake the cable out one of the corners of the frame (there's a picture) because the attached usb-a plug and ferrite core won't fit through any of the existing openings.  A little work with a dremel could probably fix that but I didn't feel like biting into my frame.
Posted : 21/02/2025 7:55 pm
WDLandry
(@wdlandry)
I just ordered the buddy cam but getting second thoughts and I also have a spare C920 lying around from all those video's call during COVID!
How did you set up the C920, just straight into a PC. Wondering if I could set up webstream with a Pi Zero as a work around.
Posted by: @emoses
Posted : 16/04/2025 9:17 am
fissi0n - K1TDG
(@fissi0n-k1tdg)
ESP32 Cam is what I have with all my MK4S printers, and I am going to be replacing the worthless Buddy3d camera with one (maybe two?) of these tonight.
https://github.com/prusa3d/Prusa-Firmware-ESP32-Cam
Posted : 23/05/2025 4:42 pm
Gerf Derp
(@gerf-derp)
Thanks for the input, everyone. Once I got my printer I started hacking ways to get a Raspberry Pi HQ camera in there. At first I just rested it on top of the acrylic which gave me a live, yet shaded and usually obscured, view. Eventually I designed a frame to hold it with magnets on the middle of the left side (see pic). I tested this placement by moving the print head around with the camera in place. I have a long ribbon which feeds out the bottom of the side acrylic panel. I designed and printed a little shim to protect the cable from any vibrations of that panel, also held in place with magnets. I got a 3mm CS lens and got it focused to the hotend.
On the Pi, I used camera-streamer (like modern octoprint) and I modded the Pi to Prusa Connect Gist to do a curl on the /snapshot url instead of using libcamera-still to avoid "camera in use" problems. This way I can casually look at Prusa Connect or obsessively look at the /stream to watch the print head zooming around. I have the pi mounted to the back because I have the Skadis mod on the left side hallow space.
As always, 80% of my printing is for my printer; but that's the fun of it too.
Posted : 23/05/2025 5:25 pm
Borreltje
(@borreltje)
I mounted my Raspberry Pi HQ camera on a corner mount with magnets, like the original buddy camera, so it sits in the corner. Got a 3.56mm lens on it and can see the stream with octoprint and make nice Timelapses. the ribbon cable goes out through the corner panels for now, I am still thinking for a better routing solution.
RPI-cam_CoreOne.mp4
Posted : 23/05/2025 8:31 pm
Gerf Derp
(@gerf-derp)
Can you share a pic of your current cable routing? Your viewing angle is probably better. I see the gantry a lot of the time, but it's enough to know a print is succeeding.
Here's mine, along with a print view.
Posted by: @borreltje
RPI-cam_CoreOne.mp4
Posted : 26/05/2025 6:46 pm
Borreltje
(@borreltje)
Well, like I said, still looking for a better routing of the cable, for now it is like this.
Mounted Camera
Cable Routing for now
Posted : 26/05/2025 7:00 pm
Gerf Derp
(@gerf-derp)
The image links are giving me 404s.
Posted : 27/05/2025 1:45 am
Borreltje
(@borreltje)
I fixed that for you. Sorry. The links now show the images.
Posted by: @gerf-derp
Posted : 27/05/2025 6:47 am
the second link is giving security messages.
Posted : 27/05/2025 8:27 am
Borreltje
(@borreltje)
That is strange, both are on the same server. Anyway, I zipped them up for you. This should work.
Posted : 27/05/2025 8:34 am
Thank you,
Posted : 27/05/2025 8:39 am
langjai
(@langjai)
I'm using a UniFi G4 Instant. I'm in the Unifi Protect ecosystem already so it made perfect sense. It records continuously and I can do time lapses.
https://www.printables.com/make/2640303
Posted : 30/05/2025 3:12 pm
mrchristian
(@mrchristian)
I'm also a unifi guy! The 40º rated limit is a bummer though.
I did a little digging, and while it's hard to find details on the SigmaStar ARM SOC in the G4 Instant, I suspect that you could remove the shielding and heatsink it. Sadly I don't have a spare one to cannibalize, but this may be something I eventually explore...
Posted : 04/06/2025 3:13 pm
j.hoekstra
(@j-hoekstra)
Offtopic, but you don't have www.borreltje.nl included in the certificate. So either only use borreltje.nl or add www-subdomain as a SAN.
Posted : 08/06/2025 3:36 pm
langjai
(@langjai)
I think there is still a lot of buffer room above the 40° threshold. I was able to print ASA at 40° and it held up fine. The G4 instants aren't that expensive so it's no big deal if I lose one.
Posted by: @mrchristian
Posted : 09/06/2025 2:24 am
