Advanced Filtration System
EvoDesigns
(@evodesigns)
Miembro
Does anyone know where the AFS would mount in the Core One, I have a MK4S enclosure filter that I want to try and retrofit bit I can't find the area it would mount.
Thanks!
Respondido : 12/02/2025 5:30 pm
andhson
(@andhson)
RE: Advanced Filtration System
The product page claims that it mounts on the back.
The Advanced Filtration System is a set containing a housing with a HEPA filter, carbon filter, and a high-pressure blower that can be installed on the back of the Prusa CORE One and fully integrates with the printer.
/Anders
Respondido : 13/02/2025 12:49 pm
Brian
(@brian-12)
I'm curious about this too.  In the pictures it appears to use the same filters as the Filtration system on the enclosure, but I've heard maybe they are smaller.  If that's the case I'll be redesigning it to use the same filters as all of my other machines do.
Respondido : 20/02/2025 1:59 am
Peter Bartl
(@peter-bartl)
I am printing a lot of ASA in my core one and am worried about long term build up of volatile residue. Do we know if the advanced filtration system will circulate filtered air within the chamber? Does it get mounted to the inside back wall of the chamber?
I do not think it would work well for chamber temperature if it vented to the outside of the chamber.
Respondido : 09/03/2025 5:29 pm
Miembro
I do not think it will be an issue.  I have two printers that I vent outside.  It makes minimal difference in temperature.
Posted by: @peter-bartl
Respondido : 09/03/2025 8:00 pm
EvoDesigns
(@evodesigns)
Miembro
Check out my design to retrofit the old filter/blower.
https://www.printables.com/model/1211108-unoriginal-prusa-advanced-filtration-core-one
Respondido : 09/03/2025 8:16 pm
Peter Bartl
(@peter-bartl)
Does this replace the double exhaust Fans on the inside? Or do they stay?
Respondido : 09/03/2025 10:03 pm
Brian
(@brian-12)
Posted by: @evodesigns
Thanks for sharing.  Nice design
I want it to recirculate the air like in the other enclosures.  I've ordered the one for the core one and and if it exhausts like yours I'll have to design something of my own that recirculates the air inside the enclosure.
Respondido : 10/03/2025 1:14 am
