Adv Filtration - bed leveling and nozzle cleaning issues
Petros
(@petros)
Membre
Hi everybody,
Since I installed the adv filtration kit for Prusa Core One I have been having issues with all my prints during bed leveling or nozzle cleaning part.
The moment I turn the Chamber filtration to "none" from the settings menu bed leveling or nozzle cleaning passes straight away.
I troubleshooted whether this is an elctrical or mechanical issue by detaching the fan box from the printer, holding it in my hand and sending a print. No issues when I hold the fan box in my hand so it is not electrical.
Actually when you have adv filtration to on which by default is 40% fan if you touch the coreone frame or place your head chin on a frame you will notice a subtle vibration. I believe this is interfiering with the load cell while doing bed or nozzle cleaning.
Anybody else having this issue ? I see noone complaining about it... Am I having a bad fan ?
I already took it apart and back again to make sure all is correct.
I can replicate this anytime....
What I do as a workaround is having adv filtration to "none" and then once the print passes bed leveling and nozzle cleaning section I select tune and turn it on again.
If this is a generic issue maybe this can be done in firmware and disable it during leveling and cleaning, no ?
Publié : 07/08/2025 3:59 pm
SgtCaffran
(@sgtcaffran)
RE: Adv Filtration - bed leveling and nozzle cleaning issues
Maybe check the fan cable for damage? I don't recognize this behaviour and I don't feel anything strange on the frame.
Publié : 07/08/2025 9:09 pm
Petros
(@petros)
Membre
Nothing to do with the cable mate, if it was damage in the cable it would either not work or not able to measure the fan speed.Only thing I can think of is I might be having a problematic fan whose bearings are not right.
Posted by: @sgtcaffran
Publié : 08/08/2025 4:59 am
