[6.5.3] Door opened/closed but CORE One thinks it's still open
[Rozwiązany] [6.5.3] Door opened/closed but CORE One thinks it's still open
JCHH
 JCHH
(@jchh)
I upgraded to 6.5.3 and started a print off this morning.  I noticed a bit of filament on the platter so quickly opened the door to remove it.
The Core ONE, gave me the new 'door open' alarm - fair enough.  However, it still says the door is still open (even though I closed itDoor closed, but door open alarm showing. Close-up of door closed, but door open alarm showing.
Edit: Just noticed that the chamber temperature is rising (now at 30° so will switch the printer off now).
This topic was modified 3 weeks temu by JCHH
Opublikowany : 08/04/2026 12:44 pm
JCHH
 JCHH
(@jchh)
RE: [6.5.3] Door opened/closed but CORE One thinks it's still open
I've just recalibrated the door sensor so I'll see how that goes.
Opublikowany : 08/04/2026 1:08 pm
Conrad
(@conrad-2)
I've never understood the door sensor "calibration" business. It's microswitch. You can hear it click. The adjustment tends to be wonky and probably needs a return spring, but just listen, and make sure it clicks on and off when the door is about 10 mm open. I think the factory procedure is trying to set it such that it alarms if you can slip a finger in the crack when the door is slightly open. IMO, too fussy.
Opublikowany : 08/04/2026 5:13 pm
1 ludzie polubili
I found and easier way to calibrate it, I turned it off in the firmware.
Opublikowany : 08/04/2026 5:20 pm
1 ludzie polubili
mnentwig
(@mnentwig)
institutional feature, can't sell to schools without this 🙂
Opublikowany : 08/04/2026 5:21 pm
JCHH
 JCHH
(@jchh)
Thanks, guys - it's seems to be working after the calibration.  Not sure if it shifted or whether I just did it wrong when I first set it up.
Opublikowany : 08/04/2026 5:52 pm
Posted by: @mnentwig
Curious, is this a EU regulation thing? My H2D doesn't have a door sensor. Wonder if the ones sold in the EU have it or is this just a Prusa thing?
Opublikowany : 08/04/2026 10:56 pm
Conrad
(@conrad-2)
There's probably some clause in the CE Machinery Directive that "encouraged" it.
Opublikowany : 08/04/2026 11:11 pm
Posted by: @hyiger
In the EU the Machinery Directive defines the core safety requirements. But I am pretty sure that similar requirements apply in the US, defined in OSHA 29 CFR 1910.212 and probably other regulations.
I bet that your Bambu H2D has a door sensor (Hall sensor) as well, and another one on the top lid:
Opening the door will turn the lights and display back on when they have switched off in standby mode. And under Settings > Print Options you can choose whether you want a notification or want the print paused when you open them during operation.  I understand that, if the laser module is installed and in use, the laser will always be disabled by the door sensor.
Opublikowany : 09/04/2026 5:26 am
Posted by: @jurgen-7
Ah, yes of course. I was so used to the mechanical steampunk vibe of the Core One that I was expecting an obvious switch I suppose.
Opublikowany : 09/04/2026 5:42 am
JCHH
 JCHH
(@jchh)
Posted by: @jchh
This seems to have fixed it - thanks everyone.
Opublikowany : 10/04/2026 10:32 am
1 ludzie polubili
