What does the + mean?
Página 1 / 4
Tim
 Tim
(@tim-21)
Miembro
Exactly what does the + bring to the Core One?  Looking online at the store I see no differences from what's sitting on my tabletop.
Respondido : 20/11/2025 8:00 am
1 les gusta
Tim
 Tim
(@tim-21)
Miembro
RE: What does the + mean?
I think I finally found the answer by going to the store page and finding the $10 upgrade kit. It features an automatic louver opening scheme, a new filament feed better suited to flex, a new spool holder design, and something else I don't recall - oh, new firmware. I pushed BUY just for the possible filament feed improvement.
https://www.prusa3d.com/product/prusa-core-one-to-core-one-upgrade/
Key features:
Automatic Top Vent Operation: The extruder now automatically opens the vent for low-temp materials (PLA/PETG) and closes it for high-temperature materials, ensuring the optimal thermal environment and creating a true "set-and-forget" experience.
Easy Flex Loading: A redesigned filament insertion point makes the process of feeding flexible filaments quick and simple.
New Bayonet-Style Spoolholder: Allows you to use various spool sizes. Ready for a direct-feed drybox.
Firmware & Performance: Includes all software updates from the entire lifespan of the CORE One, resulting in even better print quality and smoother operation right out of the box.
Respondido : 20/11/2025 8:30 am
1 les gusta
iftibashir
(@iftibashir)
When shipping costs more than the actual item, it's a pass from me. Not until I have something else to order that makes it worth paying that ridiculous hipping price.
Respondido : 20/11/2025 8:34 am
1 les gusta
Cédric
(@cedric)
Posted by: @iftibashir
You have a 3D printer, so its easy to make them yourself 🙂
Respondido : 20/11/2025 8:37 am
2 les gusta
cupu
 cupu
(@cupu)
I really don't understand the line that says
"Firmware & Performance
Is it just marketing on the product page?
I can only see two options ahead:
1. There are two firmware versions, one for core one and one for core one plus
2. Same firmware for core one and core one + with a setting to use the auto open/close vent functionality or not (i.e. I should be able to enable it on my core one - non plus - and it should just do the motions with no effect).
I really can't understand why (1) would be a good option so I guess they just wanted to have a bigger list of improvements and added that?!
Probably I am missing something
Respondido : 20/11/2025 8:54 am
1 les gusta
Butters
(@butters)
I agree but in the country I live in; I don't expect much better. CoreOne+ it shall be.
Respondido : 20/11/2025 9:03 am
1 les gusta
Butters
(@butters)
You don't get all the extras like stickers that visible notification that; yes, it's a CoreOne+ 😉
Posted by: @cedric
Respondido : 20/11/2025 9:05 am
1 les gusta
Posted by: @butters
Cut two little strips of white adhesive tape and make yourself a "+" for the door! 😉
Respondido : 20/11/2025 9:58 am
2 les gusta
Butters
(@butters)
The slumming solution. 😉
Posted by: @jurgen-7
Posted by: @butters
Respondido : 20/11/2025 10:14 am
1 les gusta
Protoncek
(@protoncek-2)
It's a bit of a shame to call this "Core One +" if only 10g of filament is added... i'm somewhat disappointed on this renaming - it's definitely not worthed.  The number of improvements i put on my Core One alone then mine should be called Core One ++++++++++ already...
The decent "plus" calling would be when indx upgrade will be added - THAT would be ok to call it "core one +"
Respondido : 20/11/2025 1:11 pm
3 les gusta
gb160
(@gb160)
Posted by: @protoncek-2
They did it with the Mini, just the change of bed probe was the only difference I think.
Respondido : 20/11/2025 1:23 pm
1 les gusta
Posted by: @cupu
I assume what they mean is: "With the Core One + upgrade, you can actually benefit from all the firmware improvements." (Namely, you can actually use the automated vent operation.)
Or maybe they wanted to say: "If this '+' upgrade looks a bit measly, please keep in mind that we have also made various firmware improvements already -- so we do continue to take care of the Core One."
Respondido : 20/11/2025 1:36 pm
1 les gusta
cupu
 cupu
(@cupu)
Thank you for the message Jürgen,
Your way of putting things makes it more clear for me. Indeed, without the added features you'd be missing out on some things your firmware can do ; that makes sense.
In regards to if this is or is not a + worthy upgrade , I am glad they did it because now the core one L and core one + are on equal grounds again (if you ignore build volume, heatbed and maybe some NFC things?!) so it makes sense. Then you need to call it something because otherwise you'd have people each having a core one that can do different things (eat some tpu easily and close the vent).
Respondido : 20/11/2025 2:31 pm
1 les gusta
All the plastic parts for the + should be available on Printable soon enough no? That's what I would expect. Might as well wait, download and print.
Respondido : 20/11/2025 3:06 pm
1 les gusta
Posted by: @hyiger
They already are: https://www.printables.com/model/1486513-prusa-core-one-to-core-one-upgrade-community-versi
There's also a link on that page for the installation instructions.
Respondido : 20/11/2025 3:26 pm
2 les gusta
Posted by: @hyiger
Perfect, thanks! I'll have to remix the vent opener to work with the magnetic top mod. And... I already have the filament sensor mod installed (not the switch but moving the magnet further away). Oh and I like my spool modification.... Seems I already have the +
Respondido : 20/11/2025 3:38 pm
1 les gusta
hmmm... The filament sensor mod is to be printed in PETG and not PC as before. I guess that means the 2 Bowden tube ends directly meet. Otherwise I have filaments what would wear down PETG in a heartbeat.
Respondido : 20/11/2025 3:47 pm
1 les gusta
Tim
 Tim
(@tim-21)
Miembro
Actually, I think I saw the new + stickers in the upgrade kit ... lol.  But my Mk3 which has been mostly upgraded to a Mk4 still says Mk3 and prints just fine.
Respondido : 20/11/2025 4:59 pm
1 les gusta
I like the switch better than the magnet mod since I would otherwise need to manually turn off the filament sensor in the UI. But I'm definitely printing this with PC (not PC-CF) instead of PETG.
Respondido : 20/11/2025 5:16 pm
1 les gusta
Butters
(@butters)
I went for the CoreOne+ kit; shipping is horrible but it's for the stickers. Now I wait for INDX.
Respondido : 20/11/2025 11:16 pm
1 les gusta
Página 1 / 4
