Webcam App to instantly view Buddy camera livestream in Core One
dmast
(@dmast)
I have been annoyed it takes clicking through about 4 different menus in prusa connect to actually get to the camera livestream, unlike the last cheap amazon webcam I was using on my Mk4s which just displays instantly when you open the app.
Tried "home assistant", "Bridge Control", HOOBS apps that were recommended on reddit. Was not able to get any of them to work. Seemed like a much larger ecosystem of stuff. Started reading about manually editing a configuration.yaml file that I could not figure out how to get to and so on.
Then found app called "IPCams" - very straightforward and worked instantly.
Just "add camera" with the following settings:
Scheme: rtsp
Host/IP - your IP address (numbers only)
Port - 554
Path - live
And it works!
Opublikowany : 26/07/2025 2:50 am
1 ludzie polubili
Frank
(@frank-2)
RE: Webcam App to instantly view Buddy camera livestream in Core One
IOS, or Android ?  Can't seem to find the app on the Android game store
Now I do have a live view, by using the Prusa app
Opublikowany : 26/07/2025 5:44 pm
dmast
(@dmast)
I found it for iphone, guessing you could find something similar for android, just needs to support rtsp and a "bring your own" camera.  Yes, you can get livestream through the prusa app, but I found its not very convenient to get in and out of the livestream.
Opublikowany : 26/07/2025 7:30 pm
tbr
 tbr
(@tbr-2)
Nice find! This means that it will work with any RTSP capable player/app. You could even hook it up to Zoneminder/Frigate/UniFiProtect. 😆
This might be useful as the URL scheme for some people, but make sure to replace 0.0.0.0 with the local network IP address of your BuddyCam (not the printer!)
rtsp://0.0.0.0/live
or if that doesn't work
rtsp://0.0.0.0:554/live
Obviously, this will only work as long as you are on the same network/WiFi.
(People who know how to set up a VPN and route traffic will know the advanced stuff ofc.)
I just tried with VLC and `ffplay` from `ffmpeg` and both work just fine!
Thanks again for the hint! I didn't bother checking as I expected the RTSP stream to require authentication…
edit: Now enjoying printer action on my living room 4K TV 🤣
Video: h264 (Constrained Baseline), yuvj420p(pc, bt709, progressive), 1280x720, 25 fps, 23.98 tbr, 90k tbn
This post was modified 8 months temu 2 times by tbr
Opublikowany : 27/07/2025 10:42 am
gb160
(@gb160)
Also, for any Kodi users you can just put the rtsp url in a file with the extension '.strm' and place the file anywhere where your Kodi instance can find it.
Opublikowany : 27/07/2025 10:51 am
1 ludzie polubili
zapta
(@zapta)
How do you find the IP of the camera? Can you set it to be static?
Also, does it work only from local network or across the internet line Wyze and similar.
Opublikowany : 29/07/2025 11:26 pm
tbr
 tbr
(@tbr-2)
Probably the simplest way is to:
  • if you haven't done so yet: Enable "RTSP stream on local network" from the Prusa app on your mobile device(!)
  • go to the "Prusa Connect" tab in Prusa Slicer
  • Click on the "Camera" tab within that (or the Prusa App)
  • scroll down the main view
  • Look at the bottom right below the camera picture
    • If you can't see the values on the right, click on the circled "i"
  • Press the copy button right next to the WiFi IPv4 address
There are many other ways, but they fall into "generic networking", like looking it up via your router webui etc., but this is the simplest.
As I already pointed out: "Obviously, this will only work as long as you are on the same network/WiFi."
There are ways to achieve this, but they go way beyond the simple scope here, as they involve additional software or hardware. As is there is no such feature and the Prusa app tells you as much too: "Streaming video via RTSP is currently only possible on the same internal network!"
Screenshots:
Screenshot of the Prusa mobile app
enable RTSP here
Prusa Slicer showing the Camera info
Opublikowany : 31/07/2025 7:29 am
zapta
(@zapta)
Thanks @tbr, this is very useful.
Opublikowany : 31/07/2025 1:48 pm
CW
 CW
(@cw-4)
@tbr-2 I can't get this to work and I don't know why. I tried the VLC iPhone app initially and that didn't work. I've been trying the IP Cams app and that's not working either. The camera and my phone are both on our Guest-WiFi network (and I'm just on the other side of a wall from the camera). The camera stream IP address is 192.168.30.20, and my phone's IP at the moment is 192.168.31.21. Is there something obvious I'm missing here? I've tried port 554, port 8554, I've tried Auto protocol, TCP, UDP, HTTP, etc., and nothing has worked. I'm beginning to wonder if there's some network security thing going on.
Opublikowany : 26/09/2025 7:54 pm
tbr
 tbr
(@tbr-2)
That might be the problem. Guest WiFi networks often are configured for client isolation.
First check if you can ping it. If that doesn't work, that's the reason.
If it works, check if you can establish a TCP connection on port 554 e.g. using netcat/nc
nc -v 192.168.31.20 554
Connection to 192.168.31.20 port 554 [tcp/rtsp] succeeded!
# OR
nc: connectx to 192.168.31.20 port 554 (tcp) failed: Connection refused
Also double-check that the RTSP streaming is actually enabled in settings.
This post was modified 6 months temu 2 times by tbr
Opublikowany : 27/09/2025 6:57 am
CW
 CW
(@cw-4)
That must be it, thank you. From my iPhone, I was able to ping my iPhone's IP address as well as the router's IP with 0% loss, but trying to ping the camera I get "host is down" or "no route to host".
Opublikowany : 29/09/2025 2:49 pm
NickAtNight
(@nickatnight)
I am using VLC Media Player on my computer.
It might also be 'Apple Security'.  Is there something you need to turn on in settings to allow the communication?
   Under settings; Privacy and Security; Local Network
Opublikowany : 20/12/2025 10:33 pm
CW
 CW
(@cw-4)
I checked that and that permission was enabled. I suspect in my case it's like @tbr-2 said, and there's a security setting on IT's end that keeps it from working.
This post was modified 3 months temu by CW
Opublikowany : 22/12/2025 2:25 pm
