Undisclosed Extra Y axis available?
darksharpie
(@darksharpie)
One of my minor disappointments with the CORE One was that Prusa only specified an increase of 10 mm to the Y axis for a total of 220.  But it appears there is a bit more on tap- you would just need a larger build sheet.  I noticed the extra space left on the rods at the Y origin when printing.
low_y_limit video clip
And editing the start gcode to push the purge line back on a larger BL sheet shows there's almost 20 mm more Y available (less if you leave a bit of headroom and in order to keep the purge line behind your print).  So it seems like Prusa could easily unlock say "235" mm of Y were they to support longer print sheets.  Or maybe they plan to put something else in that space back there.
(top line is the "stock" line position at 2.5 mm back from 0, second is edited to be 19 mm back)
This topic was modified 1 year temu 2 times by darksharpie
Opublikowany : 09/02/2025 2:52 pm
