PLA sticking to Satin Sheet on CoreOne+
I always see people having a problem with PLA adhering to satin and textured sheets, but I have the opposite problem. I just completed a print that had two small areas where supports were needed, and now I can't remove the base layer of the support area. The rest of the print released fine, but this one layer is STUCK. I'm not wanting to go after it with a metal blade, but all my plastic scrapers are not doing the job.
I clean the plate after every print with 95% IPA and a paper towel.
RE: PLA sticking to Satin Sheet on CoreOne+
I'd try putting a few drops of Isopropyl on the edge of the part. Hopefully that'll get underneath and get it to release.
If that doesn't work, try putting it in the freezer.
Thanks guys. I was able to get it off. Any insights on why it stuck there in the first place?
Single layer brim or support are hard to remove, this is a known problem and it's not limited to PLA. There is a pending request to make the height configurable.
https://github.com/prusa3d/PrusaSlicer/issues/2605#issuecomment-508963684
I pour alcohol on the area and 'whack' it almost horizontally with a plastic scraper. The alcohol weakens the adhesion and lubricant the plate to avoid damage.
... (I can't edit the post above). Here is a better link to the plastic scraper. They are very handy around the house, not just for 3D printing.
https://www.amazon.com/Plastic-Forwithout-Scratches-Adhesive-Stickers/dp/B09Y5WQFP4
Usually the first thing to try is dropping the plate temperature. Also, counterintuitively, a PVA glue stick will act as a separation layer making it easier to remove the part.
