chamber vent control
SdeL
 SdeL
(@sdel)
I just installed the Core one + upgrade kit purchased from Prusa but the chamber vent control does not work. In the settings/hardware menu it shows as "auto" (but displayed in red...). I have loaded the latest version of the firmware 6.5.3). What
should I do to have the vent operated automatically when printing with PLA?
Thanks in advance for your help!
Sylvain
Posted : 14/05/2026 9:30 pm
k1mu
 k1mu
(@k1mu)
RE: chamber vent control
Based on earlier reports, you've installed the vent incorrectly.  Double check the orientation.
Are you seeing the nextruder move left then back to the right prior to print starting?
Posted : 15/05/2026 4:30 pm
SdeL
 SdeL
(@sdel)
Yes, the extruder moves to the right and then to the left but it does not hit the vent index. I have turned the vent plate around but no success...
Posted : 15/05/2026 5:43 pm
SdeL
 SdeL
(@sdel)
I had modified the printer gcode to include a nozzle wiper on the left side of the printer: could that be a problem?
Posted : 15/05/2026 5:49 pm
SdeL
 SdeL
(@sdel)
I have gone back to the original prusa printer gcode (for core one but i do not see a core one+ version...) and the vent is still not operated. The extruder does not move from right to left before printing...
SdeL
Posted : 18/05/2026 2:06 pm
ssmith
(@ssmith)
I had this too. I missed the upgrade step to flip the vent cover before reinstalling. That was the solution for me.
Posted : 18/05/2026 5:31 pm
SdeL
 SdeL
(@sdel)
What I find strange is that the extruder does not move from its "pre-printing" position on the right to the left where the finger operating the vent is... Just a if it did not know this is no longer worked with a core one but a core one+... I suspect I do not have the right gcode....
Posted : 18/05/2026 5:50 pm
Posted by: @sdel
Whether the vent opens or closes depends on what filament is loaded. You can test this in two ways, you can create a .gcode file and print it or you can attach a USB-C cable, open a terminal application and type the commands. For example:
; Manually close the vent to start the test
M870 O    ; open vent
G4 S2     ; wait 2 seconds
M870 C    ; close vent
Posted : 18/05/2026 6:14 pm
SdeL
 SdeL
(@sdel)
Thanks a lot for your reply! Can you explain better how to run the tes: for instance, should I include the commands suggested in my current printer gcode? if so, where in the gcode? Would the following be OK:
{if filament_type[initial_tool]=="FLEX"}G1 E-4 F2400 ; retraction{else}G1 E-2 F2400 ; retraction{endif}
M84 E ; turn off E motor
M870 O ; open ventG4 S2 ; wait 2 secondsM870 C ; close ventG0 X76 Y-18 Z1.0 F10000;G0 X40 Y-14 Z1.0 F10000;G0 X76 Y-18 Z1.0 F10000;G0 X40 Y-14 Z1.0 F10000;G29 P9 X208 Y-2.5 W32 H4 ; original nozzle cleaning methodG0 X40 Y-14 Z1.5 F10000;
Sylvain
Posted : 18/05/2026 8:27 pm
Just send exactly as above in my post.
Posted by: @sdel
Posted : 18/05/2026 10:24 pm
SdeL
 SdeL
(@sdel)
I did and it did open the vent... but did not close it.
Thanks again for your help!
ylvain
Posted : 19/05/2026 8:32 am
James W7TXT
(@james-w7txt)
Has anyone noticed the auto vent control not working properly with recent firmware or slicer updates? At some point, my CoreOne started closing the vent before printing PLA. I'm wondering if it was caused by an update to the firmware or profiles. I'm running PrusaSlicer 2.9.5 and Firmware 6.5.3+12780.
Posted : 26/05/2026 1:52 am
SdeL
 SdeL
(@sdel)
I had problems getting the vent grille to open before printing and close after priniting. I deleted my user presets files and created a new one by inserting a "M870 O" line in the start G-code and a "M870 C" followed by "G1 X5 F10000" as the first lines of the end G-code. It now seems to work fine.
Posted : 26/05/2026 7:28 am
James W7TXT
(@james-w7txt)
Figured it out. The printer was shaking the vent closed. Tightened the screws some.
Posted by: @james-w7txt
Posted : 04/06/2026 12:15 am
That's an interesting data point to remember. By chance are you using the Hula Feet mod?
Posted : 04/06/2026 1:11 am
James W7TXT
(@james-w7txt)
No, I have TPU shims under two feet due to an uneven surface.
Posted : 12/06/2026 5:37 am
