PLA sticking to Satin Sheet on CoreOne+
Steve
(@steve-36)
I always see people having a problem with PLA adhering to satin and textured sheets, but I have the opposite problem. I just completed a print that had two small areas where supports were needed, and now I can't remove the base layer of the support area.  The rest of the print released fine, but this one layer is STUCK.  I'm not wanting to go after it with a metal blade, but all my plastic scrapers are not doing the job.
I clean the plate after every print with 95% IPA and a paper towel.
Opublikowany : 15/05/2026 3:04 pm
k1mu
 k1mu
(@k1mu)
RE: PLA sticking to Satin Sheet on CoreOne+
I'd try putting a few drops of Isopropyl on the edge of the part.  Hopefully that'll get underneath and get it to release.
Opublikowany : 15/05/2026 4:26 pm
Conrad
(@conrad-2)
If that doesn't work, try putting it in the freezer.
Opublikowany : 15/05/2026 10:04 pm
Steve
(@steve-36)
Thanks guys.  I was able to get it off.  Any insights on why it stuck there in the first place?
Opublikowany : 15/05/2026 10:23 pm
zapta
(@zapta)
Single layer brim or support are hard to remove, this is a known problem and it's not limited to PLA. There is a pending request to make the height configurable.
https://github.com/prusa3d/PrusaSlicer/issues/2605#issuecomment-508963684
I pour alcohol on the area and 'whack' it almost horizontally with a plastic scraper. The alcohol weakens the adhesion and lubricant the plate to avoid damage.
https://www.amazon.com/dp/B0818WBNVD
Opublikowany : 16/05/2026 2:10 pm
zapta
(@zapta)
... (I can't edit the post above). Here is a better link to the plastic scraper. They are very handy around the house, not just for 3D printing.
https://www.amazon.com/Plastic-Forwithout-Scratches-Adhesive-Stickers/dp/B09Y5WQFP4
Opublikowany : 16/05/2026 2:13 pm
Usually the first thing to try is dropping the plate temperature. Also, counterintuitively, a PVA glue stick will act as a separation layer making it easier to remove the part.
Opublikowany : 16/05/2026 2:26 pm
