Nozzle clogged when changing high temp filament
KonstisSFX
(@konstissfx)
Mitglied
Hey People,
when changing from the PC Blend Filament to regular PLA I probably hadn't preheated the nozzle enough and the PLA wasn't able to push out the rest of the PC Blend Filament during the cleaning and got stuck pretty badly.Winded up filament in the print head of the Core one.
Thank God I knew how to disassemble and assemble the whole print head so I could get it removed and everything running again.
Would there be a possibility to add a preheating in the firmware before changing the filament especially with higher temperature filaments so the nozzle doesn't get clogged by accident (unawareness)?
Best regards
Veröffentlicht : 27/01/2026 9:34 pm
Steve
(@steve-5)
RE: Nozzle clogged when changing high temp filament
There are several viable alternatives for clearing the nozzle when changing filament from high temperature to lower temperature materials.  The one that I favor personally is to use a cleaning filament (I have a similar 100g "spool" that has lasted for over 5 years now) that is compatible across a broad temperature range to "flush" the higher temperature material from the nozzle prior to loading the lower temperature material.  The cleaning filament's broad temperature tolerance means that it can be loaded at the high temperature required for PC or nylon for example but then is easily pushed through by the PLA or other lower temperature material.
Regards,
Steve
Veröffentlicht : 28/01/2026 2:21 pm
Mchad65
(@mchad65)
Are there cleaning filaments which can tolerate the temps used for hot stuff like ASA, PA or PC? The temps I see for cleaning filaments are around 230. Will that low a temp soften high temp filaments enough to be affected by the cleaning filament?
Edit: Never mind. I see hatchbox sells one that's good to 300c
Regards,
Steve
Diese r Beitrag wurde geändert Vor 3 months von Mchad65
Veröffentlicht : 28/01/2026 3:36 pm
Posted by: @mchad65
Cleaning filament can be run at 290C which is what I use. You can also use nylon filament as a "cleaning filament"
Veröffentlicht : 28/01/2026 3:42 pm
