Move MMU3 from MK3.5 to Core ONE?
Onno
 Onno
(@onno)
I'm considering buying a Core ONE and I wonder if it will be possible to move the MMU3 I have on my MK3.5 to a Core ONE. I know there still is no official MMU3 for the Core ONE, but perhaps I have missed an announcement or some other things. Will the MMU3 kit be something I can transfer between these printers?
Opublikowany : 30/03/2025 11:42 pm
altaic
(@altaic)
RE: Move MMU3 from MK3.5 to Core ONE?
It’s currently disabled in firmware, but it seems that simply enabling it isn’t enough and the firmware needs tweaking. Another user here (@WarezMonkey) tried it and didn’t succeed.
Opublikowany : 31/03/2025 3:05 am
iftibashir
(@iftibashir)
Yes, the MMU3 is a rather reliable system, and it has been stated in the blog that it will be carried forward as the solution for the Core One.
I don't know why people think there will be a MMU4, or any other new MMU system. The only change required to the current MMU3 is the way in which it will attach to the Core One enclosure, which will most likely be a new set of 3D printable brackets to replace the current ones. Otherwise, the system, and the concept, should remain.
Opublikowany : 31/03/2025 10:04 am
Scotttomo
(@scotttomo)
There s another thread where a member has documented his investigation into integrating his MMU3 to his Core 1, with limited success. Iirc he has given up as it was too problematic without the firmware update that incorporates it.
Scott
Opublikowany : 31/03/2025 10:55 am
WarezMonkey
(@warezmonkey)
Yes, I gave up 🙁 I mostly got the hardware ok to a point where it would work, but the firmware wasn't the best and I couldn't get a good slicer profile to work with the existing G-codes. I await a firmware update. But my MMU3 sits on the back of my Core One waiting for implementation
Opublikowany : 31/03/2025 7:37 pm
1 ludzie polubili
Scotttomo
(@scotttomo)
Posted by: @warezmonkey
I'm holding off building/printing parts for my MMU3 kit, save the fact I may need to print parts that may differ from the original design pending Prusa's announcement of its C1 integration. Fingers crossed that will come shortly after I get my C1........and I build it 😅
Scott
Opublikowany : 01/04/2025 10:30 pm
1 ludzie polubili
Diddleydavid
(@diddleydavid)
Firmware 6.3.1 released today now has MMU3 support for the Core One 😀
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.3.1
Opublikowany : 02/04/2025 4:57 pm
1 ludzie polubili
Onno
 Onno
(@onno)
Perhaps they will also release the files to attach the MMU3 to the C1 soon. I certainly hope so.
Opublikowany : 02/04/2025 6:05 pm
WarezMonkey
(@warezmonkey)
Yes!  I’m back in business! I hope there’s also slicer profiles for the core one with MMU…
Opublikowany : 02/04/2025 6:42 pm
2 ludzie polubili
mander
(@mander)
If I had the MMU3 on my mk4s is there anything I need to do special to the Core One to move it?
Opublikowany : 03/04/2025 9:16 pm
iftibashir
(@iftibashir)
Perform the steps to modify the nextruder and you should be good to go.
Posted by: @mander
Opublikowany : 04/04/2025 8:41 am
1 ludzie polubili
WarezMonkey
(@warezmonkey)
MMU3 now working great on Core ONE. No official Core ONE MMU3 slider profile though, but my G-code modifications worked.
https://imgur.com/mmu3-with-core-one-1d3iwCK
This post was modified 1 year temu by WarezMonkey
Opublikowany : 04/04/2025 3:29 pm
1 ludzie polubili
mikwagnercmp
(@mikwagnercmp)
So the core one Nextruder does not have the mods to work with the MMU out of the box? I assumed since it was a bowden system already it would have all the upgraded parts and you would not need to change the nextruder at all on the core one for the MMU
Hopefully they offer the nextruder upgrade kit again for the MMU since I don't think they offer it anymore, if you have a MMU3 for a mk3 you are kinda outa luck unless you source the parts yourself.
Opublikowany : 06/04/2025 11:47 pm
WarezMonkey
(@warezmonkey)
The Nextruder is the exact same as the MK4/3.9/3.5 so all mmu3 upgrades have the required parts. Really it’s very minor, it replaces the filament sensor with a different magnet. It requires the extruder motor to pull in the filament a bit.
Opublikowany : 07/04/2025 12:05 am
mikwagnercmp
(@mikwagnercmp)
I have a mk3 with the V6 hotend, only the  mk3.9/4 have a nextruder. Thus my MMU doesn't have the parts for a nextruder.
I found a kit on bluroll, the Prusa instructions indicate the Nextruder needs a main base plate under the gears. This Part here
https://www.prusa3d.com/product/main-plate-set-mmu3/
Blurolls has all the new parts in a little kit https://blurolls3d.com/products/blurolls-mjf-pa12-3d-printed-parts-mmu3-for-prusa-mk39-mk4-3d-printer-mmu3-upgrade-extruder-hotend?VariantsId=10047
Looks like I would only need to source a 3x1mm magnet as thats not included. But I bet i have something that would work in my WH 40K mini stuff lol.
Mike
Opublikowany : 07/04/2025 12:51 am
Yasar
(@yasar)
In the prusa settings.ini you can already find the settings for the coremmu3. You just have to remove the ; and it will appear when you select the core mmu3.... I'm waiting for my core...
Opublikowany : 07/04/2025 4:24 am
johnnyruz
(@johnnyruz)
So I'm actually coming from even further back and wanting to move my MMU3 from a MK2.5S to my new CoreOne.
I'm going to order the "Enclosed" version along with the longer cable as part of the new Core One MMU solution. But reading the guides it looks like the new parts list required to modify the Nextruder would be:
  • PTFE Cable Clip (Printed)
  • Idler-lever-a (Printed)
  • Idler-level-b (Printed)
  • Idler nut FS (Printed)
  • Swivel A (Printed)
  • Swivel B (Printed)
  • Screw Guide (Printed)
  • 3x1mm Magnet
  • M3x22 Screw (x2)
  • M3x35 Screw (x2)
  • Main Plate w/ O-ring
  • MMU3 X-Buddy Wiring Harness
  • PD Board
I will likely order some Prusament PC-CF for the printed parts to match the existing parts for the CoreOne. Am I missing anything here?
Opublikowany : 30/05/2025 6:54 pm
