Fixing the Automatic Chamber Vent
The auto chamber vent works well and props by the way to @Jürgen for coming up with the original idea. However, Prusa's implementation has issues. For starters, the vent is only opened or closed when the filament is changed and during an initial print. Subsequent prints do not open (or close) the vent. This can be a problem, if say for example, you run PLA and accidentally close the vent between prints. The follow g-code modification will automatically open or close the vent on every print regardless of the vent state and close the vent at the end of the print. For reference the new M code M870 O opens the vent and M870 C closes the vent. If you find these commands doing the opposite, i.e. O instead closes the vent, make sure the grill was turned over when reinstalling it. The knob that move the vent (not sure what to call it) has to be over a closed slot, not an open slot.
Add the following to the Start G-code section between the G28 and chamber temp section g-code
G28 ; home all without mesh bed level
M870 {if filament_type[initial_tool] =~ /.*(PLA|PETG|FLEX).*/}O{else}C{endif} ; Open vent for low temp materials
{if chamber_minimal_temperature[initial_tool]!=0}
Add the following to the End G-code section after the first line
{if layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+1, max_print_height)} F720 ; Move print head up{endif}
M870 C ; close vent
M104 S0 ; turn off temperature
Napsal : 21/11/2025 10:35 pm
4 lidem se líbí
RE: Fixing the Automatic Chamber Vent
One more thing to point out. If you use any of the left-hand side nozzle wiper mods, it may result in a collision with the vent mechanism and will possibly close the vent or leave it in an unusable state. I would suggest switching to a right-hand side nozzle wiper in this case.
Napsal : 21/11/2025 10:40 pm
Staldy
(@staldy)
Posted by: @hyiger
I'm using a left-side nozzle wiper and the Jürgen auto-vent, and both work together well. To avoid any collision, here is the cleaning routine:
G0 X40 Y-18 Z1.5 F10000;
G0 X80 Y-14 Z1.5 F10000;
G0 X200 Y-18 Z4 F10000;
G29 P9 X208 Y-2.5 W32 H4
Napsal : 22/11/2025 7:23 am
1 lidem se líbí
frause
(@frause)
Posted by: @hyiger
I believe you only need the M870 C in the End G-code. The firmware stores the current position of the vent and only changes it when the current chamber setpoint is under 45 ­degrees.
Napsal : 22/11/2025 2:19 pm
andhson
(@andhson)
Posted by: @frause
Posted by: @hyiger
That only works well if you never close the vent manually, for someone like me that prefer to keep the vent closed between prints to keep dust and dirt from the workshop out this mod only makes sense if it secures the correct open/closed vent regardless of what happened since the last print.
/Anders
Napsal : 22/11/2025 3:07 pm
frause
(@frause)
Posted by: @andhson
Posted by: @frause
Posted by: @hyiger
Oh, you are right! I didn't think that one completely through. It doesn't work if the vent is somehow opened between prints.
I too keep the vent closed between prints, but I never move it manually.
Napsal : 22/11/2025 3:45 pm
1 lidem se líbí
Posted by: @frause
Posted by: @hyiger
I have the magnetic top mod with a lever in front to make it easier to manually open/close the vent. I've quiet often accidentally bumped it between prints (I suppose I'm clumsy) and ruined a PLA print or clogged a nozzle. There was another instance where I took off the top between prints, stored the top on it's side and gravity shut the vent (perhaps it was just too loose). Regardless, the above maybe useful for some people but not for others.
There are also plastics where I don't need a heated chamber but I do want the vent closed because of the smell (or whatever noxious fumes it's giving off). In this case I'll be creating custom names for the filament type. I'm currently experimenting with some exotic tribo filaments and prefer not to have an open vent. I can certainly manually open and close as before but I have a tendency to forgot which is why this auto approach is neat.
Napsal : 22/11/2025 4:11 pm
Posted by: @staldy
There are a lot of wiper mods so it will depend on which one you are using. The one I'm using is specifically compatible with BIQU Cryogrip plates but is not compatible with the Core One + vent mod. In my case, I had to choose the right side option instead.
Napsal : 22/11/2025 4:14 pm
2 lidem se líbí
Sebastian Mueller
(@sebastian-mueller)
Ok so I've looked into the gcode and logic a bit, i think that your code is pretty good but i would set it using the minimal chamber temp. The start Gcode (as far as i can tell) is using this as a variable to determin if the printer should heat up to a specific chamber temperature before starting the print, this would have the benefit of also respecting other materials like PCTG or COPE as well as custom filaments (if you set the minimal chamber temp to 0). Also you're able to change these settings without adding the filament tag into the gcode.
M870 {if chamber_minimal_temperature[initial_tool] !=0}C{else}O{endif}
I've added this line at the same spot (directly afer G28)  as the original by hyiger and it works as intended.
Napsal : 23/11/2025 11:19 pm
3 lidem se líbí
Makes sense. Thanks
Napsal : 24/11/2025 2:48 am
dancan13f
(@dancan13f)
Your G-Code works fine.
Thank's 😉
Napsal : 27/11/2025 2:16 pm
Pa1nless
(@pa1nless)
it would be so much easier if Prusa would just fix the logic on their end. Inserting these loops requires you to fork the Printer Profile and unless I'm missing something will break the "Connect" functionality (which I find quite usefull)
Napsal : 13/01/2026 6:15 pm
1 lidem se líbí
Phil
 Phil
(@phil-15)
How do I modify the G Code? Are there instructions somewhere? I am running Prusa Slicer v2.9.4.  Thanks.
Prusa Core One
Napsal : 17/01/2026 4:43 pm
miroslav.h4
(@miroslav-h4)
The instructions are right at the beginning of this thread! Please take a look!
Napsal : 17/01/2026 4:46 pm
Posted by: @phil-16
Enable Expert mode in PrusaSlicer. Then go to: Printers -> Custom G-code -> Start G-code
Find this section:
M140 S115 ; set bed temp for chamber heating
{else}
M140 S[first_layer_bed_temperature] ; set bed temp
{endif}
Change it to:
M870 C ; close vent
{else}
M870 O ; open vent
{endif}
Next in End G-code add the close to the second line:
M870 C ; close vent
M140 S0 ; turn off heatbed
M141 S0 ; disable chamber control
M107 ; turn off fan
G1 X242 Y211 F10200 ; park
G4 ; wait
M572 S0 ; reset PA
M84 X Y E ; disable motors
; max_layer_z = [max_layer_z]
Napsal : 17/01/2026 5:13 pm
1 lidem se líbí
Matthew Bell
(@matthew-bell)
I just got my printer up and going and want to confirm that I have the start code modified correctly since it seems my default start code is different from the last example. This is what I modified it to:
M870 C ; close vent
; Min chamber temp section
M104 S{idle_temperature[initial_tool]} ; set idle temp
G1 Z10 F720 ; set bed position
G1 X242 Y-9 F4800 ; set print head position
M191 S{chamber_minimal_temperature[initial_tool]} ; wait for minimal chamber temp
M141 S{chamber_temperature[initial_tool]} ; set nominal chamber temp
M107
{else}
M870 O ; open ven
{endif}
Napsal : 11/03/2026 2:33 pm
The Olson Outfit
(@the-olson-outfit)
Thank you so much for this Custom G-Code.  It does what I expected from the Core One PLUS upgrade. Too bad Prusa didn't implement the vent opening and closing more like this.
Napsal : 17/03/2026 10:06 pm
1 lidem se líbí
miroslav.h4
(@miroslav-h4)
I think that FW 6.5.3 solves this problem automatically depending on the set chamber temperature, so interventions in the starting gcode are not needed. Closing the grid at the end of the print can remain.
Napsal : 18/03/2026 7:56 am
daegis
(@daegis)
Posted by: @hyiger
M870 C ; close vent
i feel this post is underrated. thanks @hyiger for the vent code fix! i ended up adding it further down just after the mesh code as i found on some bigger meshs, the head/tubing accidently clashed and closed the vent on its way back to 'home' on the core1plus.
Napsal : 04/04/2026 9:51 am
