First new nozzle
Mchad65
(@mchad65)
First new nozzle
First, I'm a hack. I print for fun and utility. I make stupid stuff for around the house, and functional parts. I don't sell things, or run a print farm, I just print for myself. My first printer was a MK3s from about 5 years ago. I ran it happily until I decided to upgrade to a Core One. Which I upgraded to a + for no real reason. So I really only know the basics. I have only ever, printed PETG. However I now want to print some stronger parts so I want to try PC-CF or other carbon fiber variants. But I do not want to have to change nozzles all the time. I want a "fire and forget" nozzle. So reading about them here, I decided on either a Diamondback .4 or an Obxidian 500 HF .4 - which I ordered and now own one of each. I finally flipped a coin today as to which I'd try first and went with the DB. Installed it, and printed a benchy. Came out fine. After reading about how the Diamondback needs to have nozzle temps lowered by 5-10 or so, looking at the benchy which I printed at the default .20 structural (not high flow) profile, I am not sure if I need to adjust temps? It looks fine to me.
So I printed a temperature tower, but honestly I don't know what I'm looking for. Seems like there are maybe some bottom layer issues at the bridges with lower temps, and maybe a little stringing at 260, but what am I really looking for here? To me, 245 or 250 look best. I used the Prusament Galaxy Black PETG I had loaded, but am thinking it probably wasn't the best choice due to the "glitter" - maybe I should redo it using plain black or grey?
Thoughts? Any reason to try the Obxidian? Or leave it alone and print...?
This topic was modified 4 months temu 2 times by Mchad65
Opublikowany : 02/01/2026 8:03 pm
2 ludzie polubili
RE: First new nozzle
Well, you have the other nozzle anyway so you might as we try it 😉
I have— and like— the Obxidian, although the normal flow type. No need to swap nozzles for any filament type or worry about the nozzle's useful lifetime.
And yes, 250 looks good to me
Opublikowany : 03/01/2026 1:58 am
1 ludzie polubili
Conrad
(@conrad-2)
I printed temperature towers in PLA and PETG expecting to see some ideal temperature. I was surprised that they looked pretty great from top to bottom. Too cold and the PETG started to look matte/flat, but the strength was still good. The bottom of the bridges never looks great. I normally go with the standard Prusa profiles for the filament type, which are on the warm end of the range. Also, try to use the "Balanced" profiles because they've been optimized for the Core One.
Opublikowany : 03/01/2026 10:41 pm
2 ludzie polubili
I think that's true for almost all quality filament these days. I frankly don't bother running temp towers anymore unless I run into a problem with the generic profiles— which is almost never.
Opublikowany : 04/01/2026 1:11 pm
2 ludzie polubili
mnentwig
(@mnentwig)
After reviewing, break it at each temperature. You'll probably notice that the lower ones come apart more easily.
Opublikowany : 04/01/2026 1:34 pm
3 ludzie polubili
Mchad65
(@mchad65)
Posted by: @mnentwig
That is definitely true. The top 4, 220 to 235 were weak, but got progressively stronger. 240 and hotter were strong as I would expect.
Opublikowany : 04/01/2026 2:40 pm
Chocki
(@chocki)
I got the DB in 0.4 as well and an obxidian in 0.4 and 0.6 which I am replacing with another DB in 0.6. I find the DB prints cleaner then the Obxidian with less buildup on the nozzle as buildup causes blobs and imperfections.
Also the Obxidian requires temperatures to be increased whereas the DB is perfectly fine at the default Prusa settings.
Opublikowany : 11/02/2026 8:38 pm
The Obxidian is 1/2 the price of a Diamondback but will still eventually wear out. The Diamondback should last the life of the printer. Unfortunately for me, the Diamondbacks will have to go into retirement when the INDX arrives.
Opublikowany : 23/02/2026 6:21 pm
Mchad65
(@mchad65)
I'll take them off your hands for a small fee 😉
Posted by: @hyiger
Opublikowany : 25/02/2026 10:11 pm
Mac-N4MCC
(@mac-n4mcc)
Temp towers are useful if you start having stringy prints with a filament, or change brands.
I have decided 3D printers were invented to print things we didn't know we need.
Extra HAM (and eggs some say) Radio - N4MCC
Opublikowany : 04/03/2026 11:27 pm
