Filament not loading
John
 John
(@john-24)
Okay Guys, I neen a bit of help here. I have a Core One that I have uograded to a +. It has been working great for the past mont or but last night after I finished with a print I shut everything down and turned the world off for some rest. This mornong when I started over again I nooticed that there was no filament being extruded when I started the first print. I did some checking nd found that the filament had broken off at the top of the nozzle. I cleared that problem and reinstalled the nozzle and did a quick check to see if there was anything else that was causing a disruption in the filament path and could not find anything. When I tried to reload the PLA Flat filament it would not go past the Idler area. All I get is a clicking noise. After some schecing I could not find anything that would be causing any blockage of the filament path. I had checked the sensor area, the gear path way and the area in and around the idler. With everything off and the opened up, I passed a piece of filament down through the filament sensor past the idler into the nozzle opening area and then on down down trhrough the fan area, All was clear. No stuck filament bits anywhere along the path. I put it all back together and tried to reload the filament again, and again it would not go past the Idler area, just a bunch of clicks as it was trying to move the filament into position and feed it on into the nozzle. Any thoughts?
This topic was modified 21 hours ago by John
Posted : 10/01/2026 5:21 pm
Ckobar
(@ckobar)
RE: Filament not loading
Maybe this is the problem ?
https://www.printables.com/model/1550370-core-one-modified-filament-sensor-base-test
Posted : 11/01/2026 10:26 am
John
 John
(@john-24)
Thanks for the reply and link to the part. I will give it a try and see what happens. After being in the military for 22 years and bouncing around this big blue marble for almost 80 years I have learned that when things don't work and you have done all you can do to try and resolve the problem and they still exist, There are times when time is the best repair remedy, plus a little bit of either Voo Doo magic or just plane old FM(you ca guess the first word and the second is magic)logic. Any way, after lunch I tried to load the filament again and this time it did load. I don't know what changed, but something moved or shifted in it's place, but it let the filament pass. It may have been the bulge, it may have somewhere else, I don't know where.Thanks anyway, this part looks like a much better design. I will print one and give it a test and see what happens. Any improvement be it just a minor tweak, is a positive improvement. Give me a day or two and I will let you know haw it goes.
Thanks again.
John
Posted : 11/01/2026 11:57 am
